Old 08-17-2006, 03:28 PM
ajferre ajferre is offline
94 Jimmy Starting Problem
Last summer (2005) I replaced the started in my truck. Around January I started having problems starting it when it was warm, by problems I mean I'd turn the key to the start position but nothing would happen -no click, nada. This happened very rarely so I figured I could live with it. That was dumb, I know.
It's gotten so bad now that it almost never starts warm or cold and most of the time I need to jump the starter manually to get it to start. I've checked the wiring on the starter and everything is tight and connected.
Has anyone run into this, or have any ideas what it could be?
All the mechanics I know have said to check the connections at the starter and once I told them I did that, they didn't have a clue.
Thanks in advance!
Old 08-17-2006, 08:55 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 94 Jimmy Starting Problem
Solenoid is stuck.
Have the starter removed and lubricated or replace the solenoid.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-29-2006, 09:21 AM
reynolds65's Avatar
reynolds65 reynolds65 is offline
92 Jimmy Starting Problem
I have a 92 jimmy that is not starting, now it will turn over but will not fire, i had to towed the other nite and AAA guy said it was not getting fuel he tried to start it but couldnt, does that sound like the fuel fliter or fuel pump???? and help i love it
Old 08-29-2006, 12:27 PM
billibong's Avatar
billibong billibong is offline
Sounds like the pump. Run a pressure test on it and post back your numbers.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
