UPDATE: ok i found the magic switch.. jumpered the little plug and turned the key on... tada! the engine light flashes and I got my code!!! apparently my EGR is messed up... i remember seeing someone posting something about taking it apart and cleaning it and it being good for a year or so more... so my next project is just that... I checked and a new EGR is like $120 or so... OEM only
![]() are any of you shocked at the check engine lights?? lol... I have a 1994 tracker with the engine light on for about 8 months now... I have the book for the truck that says "hand held computers will not work on anything under 95". You have to jumper the plug near the battery to get the computer to flash the check engine light in a certain sequence... just like all the old vehicles used to do before the smart computers came out... I have jumpered the plug and can not get the engine light to flash any sequence .. I have had the truck in atleast 4 shops that can not figure it out either... I've gone as far as unplugging all the sensors and resetting the computer(taking leads off battery for over an hour) and plugging them back in one at a time to see if I can find a bad sensor. The book I have doesnt say anything about a magic reset switch, but im going to check behind my speakers like the other posts here have stated. Any ideas while im checking into the magic switch? Gregg Last edited by Mythusprime; 08-18-2006 at 08:42 AM. |
Re: 94 tracker - check engine light
how many miles on tracker if over 30,000 ,60,000 ,90,000,120,000 the light automatically turns on get under dash and flip switch usaully by front speaker left of steering column.
UPDATE: ok.. it was the EGR.. i cleaned it out (like someone posted here) and the light went off!!! it stayed off for 2 weeks and came back on saying the same exact thing.... I took it off again and it is as clean as when I did it the first time... but now the hose connecting it (vacuum) has apparently gotten real hot and expanded and got sticky(heat does wonderful things to rubber hoses eh)... I will have to replace the hose with a tuffer hose I guess.. but why would that cause the computer to say its gone again? losing vacuum maybe?
where is the reset switch located? i have a 90 tracker and the check engine light is on, i took off the cover under steering column and the left front speaker out and i don't see any sort of switch. if anyone can take a pic and show me where its located i would really appreciate it
looked behind both speakers, no switch
On my 95 it's a slide switch. It is there, just kinda hidden. Mounted on a little bracket if I remember right.
1998 Chevy Tracker 4dr, 4wd, auto, 1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi. My other car...in need of repair it won't start any longer 1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav) |
[quote=dgee]how many miles on tracker if over 30,000 ,60,000 ,90,000,120,000 the light automatically turns on get under dash and flip switch usaully by front speaker left of steering column.[/quote
when my 92 turned 240,000 the check engine light came on. I found the switch and turned it off. Is the check engine unit still functioning. |
thats the old silly timer that says time to change the oxygen sensor. It is time based or some such rot.
modern cars actually test the OXY while driving. just reset this silly device. and forget it. but do pay attention to Check Engine lights that are real. It will send out the morse code for what is wrong. a very crude feature, to be sure. the Shop manual has the codes.
91 GEO TRACKER , & others. Restoring. |
my jgc laredo 1998 no ligth check engine before start
Is that magical switch on any trackers newer than 94. Or is it for OBD I
