Old 08-17-2006, 02:29 PM
bobmga62 bobmga62 is offline
themostat sticking????
Replaced my thermosate twice last winter.. On initial woramup, would not open up until 230 degerees or ore..
this morning, (middle of the summer, same thing.. once again...
...time foa another thermostat...could there be another issue..
also, once running I only run at about 160 to 170.... is that okay
thank you
R
Old 08-17-2006, 04:55 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: themostat sticking????
Too cold, replace the T-Stat again.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 08-17-2006, 08:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
If it won't open until 230 then it is not the thermostat, it is your rad cap.
I bet you when you go out there and open the rad cap the coolant level won't be up to the top of the rad.
Top off the coolant, and replace the rad cap witha Stant rad cap rated at 16psi.
The coolant it not completely full hence why it has to get so hot before it opens.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-18-2006, 08:34 AM
Sounds like a plan..thank you blazer LT.. WOW 12,000+ responses!!!
Old 08-18-2006, 09:52 AM
Big Tall Dumb Ass
http://www.automotiveforums.com/vbul...d.php?t=456944
See this thread also.
Old 08-18-2006, 10:21 AM
alblogg's Avatar
alblogg alblogg is offline
Yep better be glad you got a Chevy and a Blazer. These guys will get you up and going in no time, not like down on the Pontiac end I don't think no body answers threads down there.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-18-2006, 12:57 PM
BlazerLT's Avatar
AF -Advisor
No problem,
I had the exact same problem and I was about to replace the thermostat when I took the cap off and there was a lot of missing coolant and the rad was not full.
When cold fill the rad and then run the engine and allow the engine to warm up with the new rad cap off and then allow the thermostat to open which will drop the coolant level again and you add some more to top it up.
Then the rad after a couple minutes will start to overflow through the cap opening, this is when you put the new rad cap on and then fil the overflow resevoir to about 2 inches from the top.
Take the truck out for a good run through the highway and traffic and such and the system will burp out any unneeded coolant a stabilize.
And then you will be perfectly fine.
