Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 08-17-2006, 11:28 AM
tfret tfret is offline
transmission filter?
We have a 99 CR-V that we recently purchased. It has just under 80K miles and it has always taken too long to shift between gears. The engine stays at high rpm's for a long time before shifting. The manual calls for the fluid to be changed at 90K, so we went ahead and had it done early. I wasn't aware of the "honda only" fluid directive from Honda at that time, so the shop I go to probably just used ordinary ATF. However, the shifting is much better now. It shifts much quicker than before. (Should save on gas). So I'm very pleased with that, but the mechanic told me there was no filter to change. Is this correct, there is no AFT filter on the 99 model?
Old 08-18-2006, 11:22 PM
jgr7 jgr7 is offline
Re: transmission filter?
I don't want to scare you here but my 98 shifted just like that before it blew up at 89K miles just before the 90K trans service. I was lucky I bought the 100K bumper to bumper warrenty with no deductable. didn't cost me a dime and I got a free rental car all I paid for was insurance for the rental. Not sure about the filter but alot of these cars have a steel mesh filter that is cleaned and reinstalled. I always use the Honda trans and rear diff fluids. In fact I just take it to Honda and have them do both at the same time.
Jeff
Old 08-25-2006, 04:41 PM
85wonderwagon's Avatar
85wonderwagon 85wonderwagon is offline
Send a message via AIM to 85wonderwagon
My 98 awd auto crv does not have a filter.. I thought that it did for a while but when I swapped the engine I looked and discovered there is no such thing.
Brian
Old 10-07-2006, 08:44 PM
terbennett terbennett is offline
The Honda CR-V does not have a replaceable transmission filter. In fact, I've never heard of a Honda with a replaceable filter. The transmissions are designed to drain and fill. If anyone tells you otherwise, call the dealer.
Old 10-14-2006, 10:29 AM
lorunner lorunner is offline
The Honda trans only have a screen inside the trans that requires the entire trans to be dissasembled to get to it. Its not really a maintanance item that requires attention either.
However if the trans was replace at the dealer there may have been an external filter that was installed. All the reman trans come with a filter kit that is supposed to be installed when the new trans is put in. But to save time most tech's don't bother. Its easy to spot. It attaches to the cooler lines that run from the Trans to the radiator. Its a cylindrical piece.
Stop asking me about radio codes I cant get them anymore!!!
