Radio, Tach, Speedo... VSS?
Hello All, my first post here....
My sons 2000 has approx. 215K miles and last night the radio, tach, fuel guage, speedo, and cruse went out. All I can find in the wire diagram common to all is the VSS??? can anyone give me some ideas on what to look for or how to check? Thanks!! |
Re: Radio, Tach, Speedo... VSS?
first i would check all the fuses in the side of dash and under the hood and make sure its not that.
2002 CHEVY SILVERADO more pics at http://www.cardomain.com/ride/2228127 ![]() ![]() ![]() ![]() more pics at http://www.cardomain.com/ride/2228127 |
I just had a very simular problem with my truck. I checked the fuse under the hood that is for the radio and it's also for the gauge cluster. THe fuse was good but come to find out the terminals in the fuse block had seperated a bit and was cause poor contact on the fuse. If you have the same problem all his gauges will not work except the voltmeter and oil pressure gauge. These still worked on my truck when this happened. So the sum it all up check the fuse under the hood and if it's not burnt, then it may be seperated terminals.
Jake
99 Chevy Z71 Black w/ Regency Package Centerline wheels with 255/85-16 Mud Brute tires. Volant intake, vette servo, soon to add ls1 electric fans and nelson tune. |
