Old 08-17-2006, 01:46 AM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Removing rear drum brakes
'99, SE:
I read that I need to pop off the rubber plug and stick some "brake tools" to release a spring or something like this?
I just need to take a serious look at the drums, I took the wheels off, and thos back wheels are NOT rotating freely!
Thanks
Old 08-17-2006, 04:10 AM
KimMG KimMG is offline
AF - Advisor
Re: Removing rear drum brakes
Go to autozone.com and look at their free repair guide. You need to loosen the adjuster to get the drums off.
Old 08-17-2006, 10:32 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You did remember to release the parking brake, right? :P
There could be a rusty ridge around the outside perimeter of the drum would would make it quite difficult to get the drums over the brake shoes. Reversing the self adjuster as KimMF mentioned should work in this case as well.
-Rod
Old 08-18-2006, 05:41 AM
mwt878991 mwt878991 is offline
If worse comes to worse and you can't get the drum to break free you can use a 37mm socket and remove the hub nut and pull the whole hub off.
You can then get inside it and pull the parts out.
Mike
