Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-17-2006, 12:40 AM
jabjabrun112 jabjabrun112 is offline
B16a2 IN a 89 si Crx
i wanna drop a B16a2 in my crx now i know i need
Motor Mounts
Hydro Converion kit for transmision
Wire Harness Obd0 to Obd2
i want to change the computer to and Obd1 ..... how would i proceed to do that?
and what computer to use?
will the swap go right in?
what about the cable for the throttle body?
Old 08-17-2006, 02:10 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: B16a2 IN a 89 si Crx
do a search!!! noobs need to read the rules!
alright man you dont have to convert to a hydro tranny, you dont need to convert to obd2 and you can use a cable transmission. youre gonna need shift linkage, axles, complete motor, motor mounts, and an obd1 ecu if thats what youre goin for, i use a chipped p08 but you can also use an obd1 pr3. go to rywire.com cuz they have ecu conversion sets you can get which make wiring no problem. can even get the vtec wiring from them. you can use the stock harness so dont cut it cuz adapters can go on the different plugs and you can use your old obd0 injectors.
the swap pretty much drops in just gotta pound out your wall for alternator clearance and maybe notch out some areas for other clearance not too hard of a job. for your throttle cable check out junkyards or ebay for one from a del sol. i got mine out of one and it works just fine. youll have to cut the rubber stop at the end of your clutch cable to make it work but most of the stuff just syncs right up
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-17-2006, 03:05 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Why don't you just use a B16a3 so you can have an OBD-I ecu with your OBD-I motor, instead of trying to have OBD 0/I/II.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-19-2006, 09:39 PM
ok welll from what im understanding, what trans do i use? The same from 1 from the B16a2?, what other trans? i know about the Motor mounts but i thought i had to use a Cable to Hydro Converter, well worse case senerio i just get the Cable to Hydro Converter and what kind of wiring do i have to do to make it an Obd1 from an Obd2? Just to let you know im only 17 lol i know how to take out motor but wire them up is a lil tricky for me lol,
i have the Axel The motor, the Trans, The Shft Linkage, so Just the wireing and PLease explain the Trans thing to me i Kinda of confused
Old 08-20-2006, 09:54 AM
NA is Best!
You can use any B series trans. Cable would be better since your car is set up for that but if not, you can get the hasport conversion. You said you already have the motor, what motor exactly is it?
