Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-17-2006, 12:35 AM
Black Knight 00's Avatar
Black Knight 00 Black Knight 00 is offline
Send a message via AIM to Black Knight 00
boost and stock interals
i was wondering what can the stock 4g63 take as far as boost levels? cuz someone told me that if i run with pistons rings and gaskets i should be able to run at 17 psi all day long. thanks for the input guys and gals
Old 08-17-2006, 01:21 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: boost and stock interals
Um, most of us run 17psi daily... The stock internals should handle up to about 400-450hp before needing to be upgraded. The amount of boost you run isn't the thing to be worrying about on your pistons and such. You will blow a head gasket way before having to worry about anything else. Heck, I think some people are running 25-30psi when they take em out to the track. Of course using race fuel too... Take a look around and do some reading up on the subject of boosting.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 08-17-2006, 07:53 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
You can run 20-25psi all day with the right mods with no problem even more if you know what your doing
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-17-2006, 09:20 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Yup like they said the right mods!! If you plan on running over 20 psi you better get arp studs and a 4 layer metal HG or one of your choice but not stock.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 08-18-2006, 12:10 AM
thanks for the help once again. i made a new thread to see just what everyone thinks the "right mods" are
Old 08-18-2006, 02:35 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I am going to have to stay with Kevin on this, go composite as long as you can and get ARP's. Knock will eat a composite gasket far before high boost pressures will.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-18-2006, 09:04 AM
kjewer1 kjewer1 is offline
AF - Advisor
Yup, me and most of the fast locals are running stock gaskets and over 30 psi. I have however toasted motors before blowing the stock gasket. My last motor in the 2g I was at 29 psi, 64 lbs/min, and motoring my way down the track to a 11.3 at 126 when the motor let go. The HG held until the head finally lifted because I knew it was a quick pass and was not going to let off when the motor started to fail When the head lifted the pressure shot the front water pipe clean out of the pump. But, the point is that the stock HG will hold up to the power. Eventually the 255 being a pussy and leaning me out to 13.5:1 took out 3 plugs and pistons before the gasket went. ARPs properly installed are the key to making it work, as well as good tuning. Excessive knock or ridiculous amounts of timing will take out nearly any HG.
The main advantage to using a stock HG is that it will seal on nearly any surface. The Cometic and other metal gaskets are finicky about surface flatness and finish RA. People are popping these things at 20 psi on shake down passes if the block and head aren't cut to a smooth enough finish, and not all shops can or will do it. Stock gaskets are also cheap. If one blows you're out 40 bucks and 90 minutes of your time.
And to reiterate what has already been said, you can not measure the strength of the motor or any other part by boost pressure alone. Boost is airflow that you are NOT using
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-18-2006, 11:30 AM
Thor06's Avatar
Jizzed In My Pants
I also have to add that I used a OEM metal one and a composite one. The composite was like 30% of the price and sealed much better. I was runninf 130 across on the metal one, it was over 140 with the composite.
