Old 08-16-2006, 10:09 PM
87transamrulez 87transamrulez is offline
Fuel pump or new transmission
Okay so i got my transmission rebuilt by a certified transmission repair service and my Trans AM hasent been the same. I got a shift kit put in it and it lost its performance. My 87TA fuel pump is going bad but before the transmission went my car shifted to second gear at about 5.5k RPM and now it shifts at 2.8-3.0k RPM, it also doesent shift hard now which i want it to do, which is what the shift kit should cause it to do. I am not sure if its the fuel pump causing it to do that or the new transmission. And to make things worse i have to have the exhaust cut inorder to remove the fuel pump to put in a new one, becuase the exhaust is is welded . So guys what do you think is wrong, the transmission or the fuel pump?
and im pissed cuz this is the first time i have ever lost to a mustang!!!
87 TA, 350 5.7L, 35,000 miles!!! ^ABOVE^
79 TA 400 rocket,Fully Stock, Garage kept, 2 owners first my dad then me.
Old 08-17-2006, 02:10 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Fuel pump or new transmission
transmission. they probably installed the wrong transmission if they didnt overhaul your stock one, they could easily substitute a different 700R4. if they do that it will probably havfe diff shift points because of the governor, lots of cars from GM use the 700R4 and they may have put in a truck one...
eithier that or they didnt adjust everything right. take it back, make em fix it!
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 08-24-2006, 11:16 PM
ok cool thanks man, thats what i thought after thinking it over. So yeah imma go back and have them fix it, it did cost a crap load of cash lol.
Old 08-25-2006, 05:07 AM
yeah, seriously.. had to have my trans overhauled.. didnt think itd cost half what i paid for the damn car! (my 88..) your TA only has 33K on it? daamn. my 97 SS has more than 3x the miles!
Car:
285's in the back
all else = STOCK.
Old 09-01-2006, 03:55 AM
Yeah its been garage kept its whole life. then i blew the trans ( and i have no idea how) and my dad was pissed. That was the first thing to ever go wrong with it.
Old 09-01-2006, 05:46 PM
Blue Bowtie's Avatar
Registered Offender
Try adjusting the TV cable properly. That's what controls line pressure and governor override on your TH700-R4, and ultimately the shift points. .
Old 09-01-2006, 05:53 PM
Registered Offender
Oh, and make sure the fuel pump is actually the problem before you start cutting off anything. Old FPRs tend to lose it, too, so don't replace anything until you perform some diagnosis. If you think you're annoyed with a "bad rebuild" because the TV cable is not adjusted, you'll be really ticked if you drop the exhaust, axle, and tank to replace the pump, only to discover that it did no good.
Old 09-02-2006, 04:53 AM
sounds pretty sweet. i wish i still had the 88 formula. probably a defective thing from the factory.. i blew my trans..twice, in the..5-6 months i had it... (good thing it was covered under the first rebuild warranty..)
Car:
285's in the back
all else = STOCK.
