Damn Automatics!!
I've had nothing but trouble with automatics from as far back as I can remember. My first car, the CRX lost it's 3rd gear. My Camaro has just sealed its fate. I had problems with the 700R4 2 weeks after it was on the road. I bought another 700R4 from a junkyard and spent 3 weeks replacing it. Now, it does the same thing the other 700R4 did, but I have never ever burnt up a clutch on a standard. This is why I'm never buying an automatic again.
What would you do with a car that keeps breaking down as much as mine does? Do you think it's my engine and not the transmissions? Do you think the junked tranny was bad (they said recently rebuilt) ? Dare I convert this 305 with a T5? a T56??? If I shouldn't waste any more money on it, what should I do with it? I've lost so much it's not funny anymore...even with my sense of humor.
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
Re: Damn Automatics!!
Uhh since you're so in with the car and seriously there is no way of getting any of it back if you sell it, I say keep it and eventually do a rebuild.. keep it as a project not 'fixing up to sell'
I'd just cut my losses and move on, personally. I don't know what the problem is, but I've owned cars like that before. Before you lose any more in that car, cut your losses, get what you can from it, and move on. Just my thoughts though.
Im just saying what i'd do.. I mean you do want an Lt1 so just get that.. it'd be better than getting an entirely new car unless its a really incredible deal.
I think keep it. Maybe put it to the side and buy what you want to and drive that in the mean time. If you want to fix it up later down the road you can, but if you sell it for peanuts all that money would be down the drain.
I read the other thread you started on this subject and one thing to keep in mind is that a 4L60/700R4 has a dry capacity of 10 quarts sans cooling system - meaning, if you put a new torque converter on it, that had no fluid in it, you'd need to feed the system at least 10 quarts of ATF. To answer an earlier question about how to get the fluid in the TC, you pour about a quart or so into it before you put it on the transmission, then after you put it all together, feed it the other 8-9 quarts. Upon startup, the front pump will fill the TC up to capacity. A lot of this fluid will come back out of the converter when the engine is shut off, which is why you can't check the fluid with the engine off. Another thing is the TV cable adjustment - this is critical!!! The cable, where it attaches to the carb/TBI bracket, has an adjustment on it. This is performed by pressing on the "D" shaped tab, then pulling the cable back toward the firewall as far as it'll go. Then, at the throttle (NOT the pedal!), slowly open it up until it's wide open. You should hear it click into adjustment. If it's too 'loose', the transmission will short-shift due to low line pressure, meaning it will shift through the gears fast, and before the car is at 20MPH. If you have this condition STOP AND READJUST THE TV CABLE IMMEDIATELY! This short-shift condition will result in a BAKED TRANSMISSION. If the TV cable is too tight, it will have really high shift points, but the clutches shouldn't be in danger (although the reaction sun shell might).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
I always learn by fucking stuff up so... dont feel alone...
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
and if all else fails, find yourself a cheap 5 speed V8 camaro(with small problems), change everything you put in this car into that one..and burn the hell out of the evil one you got.
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
You think you're pissed.... I bought mine for $14,500 2 years ago and haven't put 1000 miles on it since, let alone driven it at all the last 4 months. Everytime I started it something broke. When I rebuilt the trans I had to do it twice. When I started re-wiring it and found out how bad the guy who had it before me actually fucked it up I actually started smoking again... and literally almost cried. My "re-wiring" project that started out around $160 is probably going to run me $1500 - $2500 by the time it's all over with. And as soon as that is finished I have to pull the engine for a rebuild.... . It really sucks, BUT... this is closest maro to what I wanted (really, really wanted since I was a kid), it took me 8 years to find it, and I had lost/missed 5 in the prior year. I wasn't giving this one up. If I'm going to own it, I'm going to know it better than my own nutsuck... that way I'll always know when something is wrong or is about to go wrong and my automotive knowledge has exponentially increased since I've started doing all this. Just next time you endeavor a task like this listen to everyone around you when they say you're making a mistake... they could very well be speaking from experience.
