does any one know if a 91 stang suspension will bolt into a 91 tbird i have a 91 sc and i know a 91 motor will fit but no clue on suspension
Re: stang to t bird
Some parts MAY interchange but it's not like the fox bodies, and outright it will not be a bolt up affair.
Re: stang to t bird
Your local junkyard should be able to tell you what, if any, parts will interchange.
Re: stang to t bird
ok so does any one know where i could find blue prints or something to check bolt patterns and the such?
Re: stang to t bird
Hollenders manual at the junk yard lists what will interchange.
Re: stang to t bird
I don't think you will find many parts interchangeable.
1991 Mustang front suspension ... 1) KNUCKLE 2) LOWER CONTROL ARM 3) STRUT 4) UPPER STRUT BRACKET 5) ADJUSTER 6) COIL SPRING 7) SPRING INSULATOR 8) STABILIZER BAR 9) BUSHINGS 10) BUSHINGS 11) MOUNTING BRACKET 12) LINK ![]() 1991 Thunderbird front suspension ... 1) KNUCKLE 2) UPPER CONTROL ARM 3) LOWER CONTROL ARM 4) LOWER BALL JOINT 5) SHOCK ABSORBER 6) BRACKET 7) ACTUATOR 8) COIL SPRING 9) STRUT ROD 10) BUSHINGS 11) STABILIZER BAR 12) LINK 13) BRACKET 14) BUSHINGS ![]() |
Re: stang to t bird
JR- How do you post the pictures?
Re: stang to t bird
Goolge Free Image Hosting and take your pick. I use Photobucket. You can also use Automotive Forums "Gallery" to host pictures. Load pictures to your host. Then just use the "Insert Image" icon - ![]() from the toolbar above where you type your reply. |
Re: stang to t bird
Thanks JR
