Is there away of lubing the Strut Bearings
The strut bearings are making a noise when turning sharp during parking. Is there a way of drilling a small hole and shuting some lube in there. Hate to replace the suckers
Re: Is there away of lubing the Strut Bearings
Based on the way it is designed I seriously doubt it. Best thing to do is remove the strut and dismantle it to get to the upper mount/load bearing.
On this one below which was noisy, the load bearing appeared to be in good shape so I used special silicone grease to lube it. Problem solved and installed a new strut. ![]()
$5.00 for a box of 32.
All I would agree with is to replace the upper strut mount/load bearing when in doubt.
If it is making a noise it is bad. Replace it. MT
I've seen some ball joints that had pretty thin metal and were zerked. But why zerk a bearing that is already bad? and just going to get worse. May need a few spot welds to hold that zerk in properly.
May need an angle drill just to get to it. Better off taking the piece off = and if you are going to do that why not just replace the bearing with a new one. If I was gonna drill a hole in it I would definately zerk it just to keep air/moisture out. My 78 Dodge 4x4 had non-tapered roller bearings in the Dana 44 (older style) front that had a zerk thru the hub. I always thought that was the way to go for 4x4, but then you need to grease every 10k miles or so. The non-tapered bearings were very stiff and would take monstrous hits with no problems. Without greasing the non-tapered bearings regularly, they would burn up fast and seize = something I learned the hard way. Older style PowerWagons (PW300) had these non-tapered bearings with zerks also. It's often much more work and harder taking the cheap route (zerking a crappy bearing) than just replacement. |
Well I did drill holes from the top into the bearing, I think I drill into the bearing area I also squirted oil into the holes Result no change.
Next question Can the strut and spring be removed as a unit with-out the need of a spring compressor. I just want to replace the strut bearings. |
Do you mean as far as taking it off the car? The complete strut assembly can be removed as a unit. After it is removed then you'll neeed the strut coil spring compressor to replace the upper strut mount/load bearing.
