Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-16-2006, 02:34 PM
getfreshco getfreshco is offline
blown head gasket...
i know for sure i have a blown head gasket.... i have oil in my coolant.....i also think its my oil cooling lines or w/e they are called ...about how much is this gonna cost to get fixed or should i just invest in a new motor...cause i also would hear this metallic grinding sound....some \one told me it was spun bearings....any way should i just invest in a new motor
Old 08-16-2006, 10:35 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: blown head gasket...
A spun bearing generally has a sharp knock or dull thud sound (depending on whether it's a rod or main bearing), not a grinding sound unless there's no oil pressure (I can't see the engine running if that's the case).
I'd probably look into a new engine or a rebuilt engine. It's likely it's been leaky for a while, and coolant got into the oil resulting in the bearing failure(s).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-16-2006, 10:48 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
You sure the trans cooler isn't leaking into the radiator?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
