Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Classifieds
Old 08-16-2006, 02:21 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
WTB injectors S-afc
Tittle says it all. Im looking to some fuel upgrades for a incoming evo 16g. injectors i guess around 580-680. and a s-afc 2. also a walboro 190 would be good but i can pick that up for cheap. Thanks
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 08-18-2006, 02:09 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: WTB injectors S-afc
If you are only going to be on the evo III, I would get 550's. They'll support ~420 hp, thats more than you'll get to on that turbo.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-18-2006, 02:15 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
gonna have to disagree and say the 550's can't flow THAT much, not on stock fuel pressure anyway. Since you're still on a safc then 550's will work best, timing advance is too much over 550cc's, you just won't be able to run high boost. like 20+ without leaning out.
now - 2000 civic
soon - 2002 is300
Old 08-18-2006, 02:26 AM
Thor06's Avatar
Jizzed In My Pants
Really? This is the formula I was using:
injector cc X .1902 X # of cylinders = max horsepower (X inj duty %)
That would put the 550's at 100% IDC at 418 hp and some change. Cant argue whith experience though, who knows whos ass that formula came from.
Old 08-18-2006, 02:31 AM
the formula is correct, however, IDC's should never be close to 100%. Plus it all depends on the afr he wants, I doubt that formula allows for a safe tune. Plus when I talk hp numbers it is strictly whp numbers, not sure if that's what you meant.
now - 2000 civic
soon - 2002 is300
Old 08-18-2006, 02:33 AM
Thor06's Avatar
Jizzed In My Pants
Ahhhhhh, gotcha.
Old 08-22-2006, 09:19 AM
so i guess my estimate was somewhat right with injectors. 650's approx
Old 09-20-2006, 09:55 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
what does the ".1902" mean?
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
