Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-16-2006, 12:30 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
OEM vs. Autozone
I was thinking about it today and realized I needed a new waterpump. I got to looking and an OEM one costs like 120 dollars whereas the Autozone ones cost 40 somethin... Do you guys think the Autozone one would be just as good as an OEM one or should I only buy OEM accessories? The same thing goes with the starters, OEM is 170ish while Autozones is 120...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-16-2006, 12:32 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: OEM vs. Autozone
personally when it comes to accessories that require a lot of time and labor to replace I always go OEM, (timing belts, water pumps, oil pumps, etc.) If it's something that is easily replacable then the vatozone stuff should be fine. After all, if it breaks, then it's easy to replace and it will probably still be under warranty.
now - 2000 civic
soon - 2002 is300
Old 08-16-2006, 09:54 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I look at it this way: If it's something really important to the life of your car and your not sure of the quality of non-OEM, go OEM. Something like a blown oil pump could be devastating to your car, you would hate to know you only bought the shitty Autozone one to save a few $$. If it's something that if it breaks or screws up your entire car won't be destroyed, then give it a try.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-16-2006, 10:07 AM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
It also come down the the quality of the part and who makes it. Many mechanics stand by NAPA parts for their quality and warranty, even if they cost a little more then AutoZone or Checker.
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 08-16-2006, 11:20 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I've noticed that alot of parts from napa or stores like that are the actual oe parts and if not they have a better warrenty and are usually just as good
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-30-2006, 10:56 AM
dmc67 dmc67 is offline
Send a message via AIM to dmc67 Send a message via MSN to dmc67 Send a message via Yahoo to dmc67
get an autozone water pump their guaranteed for life.
Old 08-30-2006, 08:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I agree with crunchy. And Brian, with all the money you're investing in the motor, why not go OEM. What if, just what if that Advance (or wherever you get it) waterpump goes to shit and your overheat the shit out of your motor. You'll be kicking yourself for not spending the extra $80 for an OEM one. Parts stores do have good products, but it's just a mental thing with me that the important parts need to be OEM.
95 Talon TSI AWD
97 Eclipse GST
Old 08-30-2006, 09:48 PM
Right, I've been leaning towards OEM on that for a while now here... I'm still debating the thermostat though. I can get a 160 thermostat at autozone. Think there would be any problems with running such a cold thermostat? Stock is 190 I do believe...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-30-2006, 10:10 PM
blk_srt's Avatar
if you dont plan on driving it in the winter or cold weather I wouldnt even put one in but if you do I'd go 160
Mods:
Old 08-30-2006, 10:44 PM
I'm not gonna drive it in the winter unless I have to... Why would that matter in this decision? lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-30-2006, 11:10 PM
b/c No thermostat in the winter means no warm air. or it takes for ever for it to heat up to get the warm air.
Old 08-30-2006, 11:23 PM
Oh my bad, I misread Scotts post completely. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-30-2006, 11:30 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
If it's a newer car with an ECM/PCM, you'd better not go any lower than a 180. If the engine never reaches a set temp, it will stay in open loop and get horrible milage, and wear the engine out faster. Even the oil needs to be at a certain temp. before it fully protects your engine...Which is why I never hotrod until it's fully warmed up...
As far as vatozone 'n' Ho-reilly, If it's a pump with stamped steel anywhere on it, turn around and walk out. I bought a pump at autozone for my car that had a stamped steel impeller. It was a piece of crap. I took it back and got one with a cast impeller. It al has to do with the quality, not so much as where you spend your money..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-30-2006, 11:33 PM
What do you mean it'll stay in open loop?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-30-2006, 11:40 PM
Open loop is when the ECM is running the engine on a pre-programmed fuel output set by the factory, kinda like a limp mode..sort of. Once the oxygen sensors heat up to operating temp, and other sensors like the coolant temp sensor senses the coolant is warm enough. When this happens, the ECM uses the signal from the O2's to regulate fuel output, so the combustion process is more accurate.
