Old 08-15-2006, 11:22 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Breaking in transmission
I'm starting to break in the new transmission, I only filled it with 4 quarts of dexIII/mercon ATF. At first when I ran through the gears, it made a sucking noise like it was dry, then after a few minutes EACH GEAR vibrated slightly but did not kick in, especially reverse which usually does. What could be the problem?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 08-15-2006, 11:37 PM
Dyno247365's Avatar
Re: Breaking in transmission
Okay new problem, the gearbox isn't working. No matter what I shift to.
Old 08-16-2006, 12:02 AM
97cavalier's Avatar
97cavalier 97cavalier is offline
did you put a new filter in the tranny you got in there now? make shure you have the TV cables adjusted right befor you go driving it,other wise you will fry the tranny.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 08-16-2006, 12:20 AM
Dyno247365's Avatar
Yes there's a new filter, I just did that today. Also, I connected the TV cable the way I took it apart, how do I adjust it?
Old 08-16-2006, 12:28 AM
97cavalier's Avatar
do you have a hanes manual? or a repair manual? it will tell you in there, i am not shure on how you adjust it.
Old 08-16-2006, 09:20 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
TV adjustment (normally) is done by pushing the detent lock in and sliding the adjustment tab all the way in (back). Release the detent lock and manually open the throttle slowly and evenly to WOT. The tab will pull out and settle in where it should based on cable condition.
Now, in reality, unless it's a brand new cable assembly, that's not going to be the case, you'll need to adjust accordingly. Do the above and see how it shifts. If it's soft, manually push the detent back 1 notch and test drive again. If still soft continue 1 notch at a time ONLY.
The same applies to if it were shifting hard, just bring the detent out 1 notch at a time until it's accepatable.
However, I think fluid is the issue here. The torque converter alone eats quite a few guarts. And even if it was full (T/C) 4 quarts omly in the trans seems a litttle light, isn't it more like 6 or 7? Don't remember off the top of my head.
Old 08-16-2006, 10:48 AM
Morley Morley is offline
4 qts of fluid isn't going to be enough, especially if the trans and torque converter were both empty. A 700R4 holds a total of 10 qts of fluid.
Old 08-16-2006, 10:52 AM
wrightz28's Avatar
That's what I was thinking, about 4 in T/C and 6 1/2 ish down the tube.
Old 08-16-2006, 11:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You need to fill it up with fluid before you burn it up.
If you have not already burnt up clutches.
MT
Old 08-16-2006, 04:15 PM
Dyno247365's Avatar
Oh shit, I didn't fill up the TC. How was I supposed to do that?
Old 08-16-2006, 04:18 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Put more fluid in.. The pump will fill up the converter.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-16-2006, 04:19 PM
MT-2500's Avatar
AF - Advisor
Add about 5 more qts in dipstick tube and start checking the dip stick.
The TC wiil take care of itself.
If the transmission was dry they take 10-11-12 qts.
MT
MT
Old 08-16-2006, 04:22 PM
Dyno247365's Avatar
Originally Posted by MT-2500
Add about 5 more qts in dipstic tube and start checking the dip stick.
MT
thanks, hopefully I didn't burn anything while testing it. Stupid Haynes manual says 4.7 quarts
Old 08-16-2006, 04:25 PM
I'd stay away from running it thru the gears until it has around 7 to 8 qts. in it. Hey, at least you don't have a C6 or E4OD, they take about 13qts..
Old 08-16-2006, 05:14 PM
Dyno247365's Avatar
Forget an automatic C6, I hate automatics. I need a clutch and a shift knob on my best cars. I heard the 700R4 was strong though.
what would happen if I overfilled it? what would the tranny do?
