Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-15-2006, 10:31 PM
Bodack Bodack is offline
Send a message via AIM to Bodack
Charging system problem
I read a few previous threads about the troubles power steering fluid on an alternator can give you, and I think that might be my problem. The other day I had my power steering pump off and tried to reroute the fluid to a can, but a lot spilled on the alternator. I put everything back on, drove for a while, shut the car off, went to crank it again and it was dead. I got a jump, let the battery charge a bit, the took the cables off of the battery and it went dead. I diagnosed the alternator being dead, then got a new one. I installed the new one, got a jump, but the alternator still wouldn't keep the car running. I do have a slight leak on top of the power steering pump at the banjo connection and there is a slight possibility that a few drops of fluid got on the alternator. Would this be enough to kill a brand new alternator (it's warrantied, so I'm not out of the game yet)? Also, when I drove the car after putting the steering pump on, the coolant, e-brake, and battery lights would come on at idle, but if I revved it they would go away until the RPMs dropped back to idle. Suggestions?
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 08-16-2006, 12:35 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Charging system problem
It only takes a few drops to fry an alternator. Been there done that
Regarding the lights, the ebrake and the battery light will come on with a dead alternator, at least on a 2g. Perhaps on a 1g the coolant light also comes on, someone else will have to chime in. No clue about them dissapearing though with a rev. Perhaps since it's drawing more power, but mine stayed on no matter what. It's like a countdown lol
now - 2000 civic
soon - 2002 is300
Old 08-16-2006, 02:05 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Charge your battery fully before putting on a new alternator. All that load on a fresh alt. can fry one.. Been there with the PS fluid on the alt....
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-16-2006, 11:03 PM
Well the alternator was definitely fried. I took off the power steering pump because I found the leak on the power steering pump. It's where I gouged the flat area around the banjo bolt fitting while trying to get it loose . It'll be a few days before I can get a new one, so I pose this question...will it be so hard to steer with the pump/belt off that I just won't be able to drive, or will it be ok for the time being?? A friend said it's worse than driving a car that was meant to not have power steering, but I know of people (possibly DSMers, but Honda owners for sure) that take off their power steering belt to free up as much power as possible? So, what's gonna happen if I drive it?
1993 Honda CBR900RR
Old 08-16-2006, 11:16 PM
I'll guess it's gonna build up your upper body....
Old 08-18-2006, 09:51 AM
Not having power steering wasn't so bad on the Interstate. I had to make a drive from Nashvill, TN to Montgomery, AL and really just right-hand 90 degree turns were the only problem. I thought about just leaving it off, but the $100 for the new pump isn't too bad. Thanks for all the help.
1993 Honda CBR900RR
