Old 08-15-2006, 06:38 PM
missmist1 missmist1 is offline
1995 lesabre wont start
I have a 1995 Buick Lesabre.It was running fine.No problems what so ever, then I drove to the store, parked, and when I went back it It would crank but not turn over.
It has spark,compression but no fuel.I checked the fuel line at the fuel filter and had no fuel before or after the filter. Anyone have any ideas? I really need the car by Thursday. Thanks for any help with this.
Old 08-15-2006, 06:54 PM
grcore grcore is offline
Re: 1995 lesabre wont start
Check the fuel pump relay and fuse. (located under the dash on the passenger side).
The fuse is in position 6 and the relay is position N.
Old 08-16-2006, 05:09 PM
Tried that and replaced tthe fuel filter and pump. Ran today,parked ran again. Died in driveway. Ran for less then 10 miles total. Is it the ECM?
Old 08-16-2006, 05:28 PM
Its possible. Are threr any error codes?
Old 08-16-2006, 06:22 PM
maxwedge maxwedge is offline
A990 racer
Can you here the pump run in the prime mode when first turning the key on, try switching the fp relay with a like one in the relay panel under the hood.
