Old 08-15-2006, 07:29 PM
Spider228 Spider228 is offline
S-AFC 2 Problems
I got a 93 dx and i just tryed to put in an afc to controll my injectors for my turbo setup. When i hook up the yellow and white wire the car wont start. I did the intial setup and tripple checked everything. The car wont start. I am for sure everything is hooked up properly.
Red= Power
Green=Rpm
Gray=Throttle
Brown=Ground (Ecu side)
Black=Ground (1cm Apart)
Yellow=Pressure signal output (Ecu side)
White=Pressure signal input
This is what i used to install it.
http://i94.photobucket.com/albums/l1...0211/apexi.jpg
Old 08-17-2006, 04:24 AM
hany's Avatar
hany hany is offline
Re: S-AFC 2 Problems
i see that all your wire is correct.
so try to remove all the wire and start the engine . if it start ok then rewire the safc 2 again then start the engine if not it will be some thing from three things 1- the safc2 itself have a problem
2- the wires is bad
3- wrong wire
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 08-17-2006, 12:56 PM
it will start and run fine with the white and yellow not hooked up, but when i hook them up it wont start. The rpms read fine the throttle percentage is good and the throttle voltage is good. Its the yellow and white wire that is giving me a problem.
Old 08-18-2006, 05:30 AM
hany's Avatar
what did you do the injector percent at 1000 rpm at the low throttel it suppose to be -40% did you do that ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 08-18-2006, 11:39 PM
yep and it still wouldnt start
Old 08-19-2006, 04:41 AM
hany's Avatar
i think you have to try other safc2 from any friend . but be sure it work good. then try only the other safc2 unite at your wires . then if the engine start that mean your unite has a problem . if not start that mean your wires has a problems.
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 08-19-2006, 10:19 AM
ive been trying to find someone with one so i can do that but nobody has one thats why im asking yall.
Old 08-19-2006, 01:48 PM
hany's Avatar
iam from EGYPT . if i were in usa i coud helped you
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 08-19-2006, 02:54 PM
well ill keep trying and ill update you and let you know. thanks anyways
