Old 08-15-2006, 05:26 PM
poormillionaire2 poormillionaire2 is offline
Header Placement
Ok, so I got the driver's side header in and all the things associated with it (plugs, wires, knuckle, etc.) But I couldn't seem to get the passenger side header in all the way; top or bottom. My friend and I both think that if we had the car up a few more inches, that there wouldn't be a problem. But the jack is maxed out and its not high enough. Any good idea, EXCEPT loosening the motor mounts and jacking the engine. That is not a possibility for me. This is starting to get frustrating. (94 Z28)
Side note: Thanks again, in advance, Cuda.
Old 08-15-2006, 06:05 PM
jcase350 jcase350 is offline
Re: Header Placement
You could use a couple of 2 x 4 pieces of wood on top of the jack to give you some added height.
1990 Iroc-z 350 TPI
Old 08-15-2006, 06:17 PM
I think I'm gonna use that as a back-up plan. But I'll probably have to resort to that anyway. Unfortunately, I won't be back under the car til Thur. afternoon.
Old 08-15-2006, 10:14 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
if anything id get a big piece and put it UNDER the jack, seems a bit safer
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 08-15-2006, 10:21 PM
NoRiceHere01 NoRiceHere01 is offline
can i ask y u cant jack the engine?
Old 08-15-2006, 10:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
He probably doesn't want to mess with it - it's a bit of extra work that might be redundant.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-17-2006, 03:49 PM
So, I'm at a dead end now. I have a few big cement blocks at my house and I put some under the car and sat the jack on top of the cement blocks. But that still wasn't high enough. I don't know if there's a special angle to slide these in at or if I need to go higher. I don't feel safe going any higher though. Any suggestions please. I need help.
Old 08-17-2006, 04:32 PM
Are you sure they are the correct headers for your car?? If so what are they getting hung up on?
1990 Iroc-z 350 TPI
Old 08-17-2006, 04:33 PM
Are you sure they are the correct headers for your car?? If so what are they getting hung up on? You might try calling a local exhaust shop and pick their brain. Never know they might give you some ideas.
1990 Iroc-z 350 TPI
Old 08-17-2006, 04:41 PM
Yeah, I'm sure they are the correct headers. I have already put the driver's side on. I'm just trying to get the passenger side header up into place, but I can't. The fender wall and the K-member are getting in the way. It looks as if I had enough room, I could stand the header almost straight up and angle it in there, but there isn't enough room. People said they have done it with jack stands, but I don't see how. I can't seem to drop it in all the way from the top either. The primaries get squeezed between the valve cover and fender wall. Anybody got any tricks?
