Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 08-15-2006, 04:38 PM
Odium Odium is offline
Intermittent Glitches (AC, Locks, Windows)
I seem to have developed a case of gremlins in my 1996 98. It has a host of glitches. When starting the car (Especially on hot days), it takes ~20min for the AC to stop pumping air through the defrost and side vents and divert it to the dash vents no matter what setting the AC is on. Is it normal for it to take so long to switch over? Also during the hotter days of summer, the keyless entry/power locks/windows seem to stop functioning properly. Sometimes the remote won't do anything and other times the horn will honk like it has locked the car but the doors don't actually lock until I manually use the lock slider. The interior power lock/window button has no effect either when its acting like this. I can manually raise and lower the windows with the individual switches but the driver's master window panel is dead. Any ideas? Thanks!
Old 09-04-2006, 03:05 PM
dougielx dougielx is offline
Re: Intermittent Glitches (AC, Locks, Windows)
Check your main ground cable for corrosion and clean it if necessary and put some dieelectric grease on it. Could cause electrical glitches.
Old 09-05-2006, 11:23 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
A bad Body Control Module comes to mind....
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
