Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-15-2006, 11:46 AM
kidcaffeine kidcaffeine is offline
thermostat
i wanna install a new thermostat... can someone give me a quick run through?...how hard? how long? and ..how?
Old 08-15-2006, 12:20 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: thermostat
What year truck? What engine?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-15-2006, 01:42 PM
surferfletch surferfletch is offline
Re: thermostat
How many miles? Original rad? Why the swap out?
Old 08-15-2006, 08:00 PM
Re: thermostat
2001 rodeo v6 4wd it has 120,000 miles and i am trying to fix a long time problem ive been having help anybody
Old 08-15-2006, 08:07 PM
Isuzu Guy
Re: thermostat
what is the current issue?
I haven't read of anyone with a +98 with thremostat issues yet?
-Ryan
Isuzu Moderator
Car Show Tips
Old 08-15-2006, 08:25 PM
Re: thermostat
my mech said that my engine is running way to cold, and that i should change it..? i dont know man this car is drvin me nuts
Old 08-15-2006, 09:20 PM
Re: thermostat
Surprised me. Thought we were heading for another radiator swap. Isn't the '98+ thermostat housing right up top at the front of the engine like on the '97? It's a pretty easy job. Just get a new gasket and make sure the new t-stat is pointing in the right direction and the top is up. Clean up any old gasket material. A little rtv will help hold the new gasket and t-stat in place when you close the housing back up. Make sure it's seated properly. Do these t-stats fail in the open position?
Old 08-15-2006, 09:25 PM
Ramblin Fever Ramblin Fever is offline
Re: thermostat
I thought people did new thermostat's as precautionary measures after so many thousands of miles.
I changed my original at 115k as precautionary measure; you don't want the thermostat failing in the closed position, been there done that on another truck.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-16-2006, 08:34 AM
2000izusu 2000izusu is offline
Re: thermostat
on my 2000 you have to take the upper plennum off for sure to get to it(maybe more stuff). it is buried down in the intake manifold valley. i think 98 was the change over year to the new style manifold and throttle body location. while ur there might as well do img's. somebody correct me if i am wrong but 98+ has the newer style 3.2 with the buried thermostat? i will not be replacing mine until i have to. unlike on other vehicles were i do it as a preventative.
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 08-16-2006, 12:12 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: thermostat
2000izusu is correct. On 98+ the t'stat is burried under the intake manifold another of those things you have to remove a minimum 3 things to get to I havent changed mine, I dont know if you can get to it by removing the throttle body or if the whole intake has to come off for it.
I know I wont be doing mine until I have to (or have to take off the intake for some reason). I will be going with an OEM isuzu one though, this has lasted 94k miles so far, much better than any Stant or other brand I've used.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 08-16-2006, 02:18 PM
Re: thermostat
I changed my t-stat with my last coolant flush. The OEM lasted well over 100K. I'm curious to see what happened with the original posters t-stat.
So the 98+ sucks to get to the thermostat. It's also buried in the 4 cylinder engine.
Old 08-16-2006, 04:30 PM
Re: thermostat
If it's buried, I for sure wouldn't fret with it til need be.
I did replace mine with an OEM Isuzu one - wouldn't touch one's on the market with a 10' pole.
It's good to know they last for a long time. The one on my '91 Rodeo didn't even make it to 75k miles before we had to swap it out.
I'll be sure to leave this one alone for well over 100k miles, it only has 30k on it now.
1997 3.2L V6 Rodeo
