Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-15-2006, 03:32 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Pulling engine... almost out, a few questions
Ok, so I am pulling my engine to rebuild it. Well, I am balls deep in it but I have done all I know how to do. I cannot figure out how to get the speedometer cable off. I unscrewed the deal and unbolted the driven gear bolt and I cant figure out how it comes out. Also, what the fuck am I supposed to with the slave cylinder lines and what not? Thanks guys... cant wait to get it out and see what the fuck is going on.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-15-2006, 02:28 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Pulling engine... almost out, a few questions
The speed cable should slide right out once you unscrew the ring that holds it down.
The slave can be left attached to the line. Just flop the slave up out of the way and rest it on something so it doesn't come apart (if you can keep the piston in the slave you can sometimes get away without having to bleed the clutch when you're done).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-15-2006, 07:02 PM
Thor06's Avatar
Jizzed In My Pants
Ok, so I gotta pull harder on the speed cable then. I am kinda confused on what part I should be unbolting for the slave cylinder. Where is it?
Old 08-15-2006, 07:35 PM
AF - Advisor
There are two M8x1.25 (12mm head) bolts holding it to the bellhousing. It's right in front, by the front motor mount.
Kevin Jewer
Old 08-16-2006, 12:04 AM
Thor06's Avatar
Jizzed In My Pants
Oh, ok. Thanks Kevin. Cant wait for it to get out and see whats fucked up. The butt plug wont come out so I cant see if theres any goffy shit in the oil. A butt ton of pictures and questions will be coming hopefully by saturday.
