Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 08-15-2006, 02:10 AM
kissiesue kissiesue is offline
Question Code 12 for a 95 intrepid
We have a 95 dodge intrepid that has never had any problems until recently. When driving home one day it completely died and refused to crank. 4 hours later we went back it cranked and drove straight home. The next day drove it 15 miles to work, no problems, then on the way home it started. It would sputter and stall then die, I put it in neutral and it cranked back on it's own. After more spitting and sputtering it died I put it in neutral and cranked it myself, after getting home and it sat for about 30 min it wouldn't crank again. we hooked up a test light to see if it was the fuel pump or the electricity to the fuel pump, it was the electricity. And when he stopped to look at it, it would not crank again, until about 3 hours later. When we got it home we checked the diagnotic codes and got a 12 then 55 (final code). What is a 12?????
Old 08-15-2006, 09:22 AM
KManiac's Avatar
KManiac KManiac is offline
Re: Code 12 for a 95 intrepid
Across most of the Chrysler car lines, Code 12 means: "Problem with stand-by memory circuit. Direct battery input to controller disconnected within the last 50 ignition key-ons." The most common cause of this code is disconnecting the battery. I suggest you check your battery connections, both at the battery and the starter.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
