Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-15-2006, 12:32 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Always, turbo Question.
ok, so i decided that i want either a 50 or 60 trim turbo... my question is this, whats the difference on turbo lag? i'm getting a "stage 5 turbine" w/ manifold mount waste gate, ported inlet and outlit...now whats the difference between the regular 50/60 wheel and the super 50/60 wheel? i know with a 60 trim wheel, the lag is going to be longer, but another question is it worth it for the power? i'm hoping for a minimum of 400 WHP w/ 950cc FIC injectors, DSMlink w/ GM bar sensor + wideband o2, STREET car. which turbo would fit my needs best?
Old 08-15-2006, 12:42 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Always, turbo Question.
Do you plan on doing internals? Either turbo will get you there, but the 60 trim will get you all the way into the 550-600 range
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-15-2006, 02:19 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
SBR said their 50 trim made 450 and their 60 trim made a bit over 500. I dont know man, are you comfortable with buying used? I would go with whatever you can get cheapest. There should only be miniman lag difference, IIRC the 50 trim will boost by about 3800 and the 60 trim will get full boost by a hair past 4000. Either will get 400, its just how much you'd want past that. I would say 60 trim because it will be easier to get 400.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-15-2006, 04:19 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
from personal experience the 60trim is not a pump gas friendly turbo. It needs race gas and really high boost to reach its power potential. IMO the 50trim is the King of Pump gas for street turbos. Good spool, plenty of power, 93 octane friendly.
now - 2000 civic
soon - 2002 is300
Old 08-15-2006, 08:53 AM
steviek's Avatar
steviek steviek is offline
yea like ricer said I think your jumping the gun a little bit, your engine won't last long under that kinda pressure. For 400 WHP your going to have to do some internals.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-15-2006, 01:26 PM
kjewer1 kjewer1 is offline
AF - Advisor
Stock internals, even 7 bolts, will make 400 whp all day long if it's properly tuned. If the motor can't take it, it was a worthless pile of donkey biscuits and deserved to blow up anyway.
I don't have any personal experience with turbos in between the 50 trim and the 60-1. The scenario I always provide to illustrate the reason I didn't spend any time testing those turbos is Forced Performace's Green and Red. They used to offer the Frank 1-6 or so, using all of those TO4x wheels. They eventually dropped that whole line and offered on the Green and Red, 50 trim and 60-1. FP knows turbos, so I tend to follow what they are doing to some degree.
That being said, the 60 trim may still make a good turbo, but I suspect Crunchy is right, and will aggre with him that the 50 trim is an awesome pump gas turbo. Dre did 500 whp with it with a larger hot side (alledgedly). I believe it is FP that sells the "Dre Spec" 50 trim. Lag would be slightly higher, but max power output would be higher, and it would take high boost on pump gas nore easily. Something to consider.
I never looked into the "Super" 50 and 60 trim wheels, IIRC, they are T3 wheels and are pretty small, no?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-18-2006, 02:08 AM
Black99GST's Avatar
what are the prices and where can i purchase this turbo your talking about keven? can i get it from SBR? or somewhere special? any good hits for a used one? i need something on a mitsubishi Housing, because i already have my manifold, and its from DP, so i PAYED for it... thanks for the input guys. and i do NOT plan on doing internals, however, the car will only be driven twice a month, and if it does break, then a 6 bolt stroker will take its place. YEAH!
Old 08-18-2006, 02:18 AM
Thor06's Avatar
Jizzed In My Pants
FP makes good shit, but they are wayyyyy to expesive IMO. You can get an SBR 50 trim for $700 or a green for $1300. If you were a hard core racer it would probably be different, but shit. You could get link AND a 50 trim for the price of the green. Just my opinion though.
Old 08-18-2006, 02:21 AM
this is the turbo you want
http://linux.forcedperformance.net/m...Code=DSM-Turbo
been working on a car with this turbo and I'm VERY impressed with how it performs. I will be upgrading to this eventually.
I don't think it will hit 500hp without really high boost, but at 500hp, your motor will break, not a question of it, but when, so this is a great turbo compromise.
now - 2000 civic
soon - 2002 is300
Old 08-18-2006, 07:43 AM
AF - Advisor
The FP green is just a 50 trim wheel with a TDO6H turbine. It does seem over priced. But, it's hard to go wrong with FP. I Don't see the Dre version on thier site, not sure if it was FP that made it now.
Kevin Jewer
