Old 08-20-2002, 11:50 PM
dbartoschek's Avatar
dbartoschek dbartoschek is offline
RMS? huh?
Hey,
I know nothing at all about car stereo's!
I'm looking for a cd reciever to replace the tape one in my cars, and i always see all these numbers which i have no idea the meaning to?
For example,
22 W RMS x 4
what does this mean?
Also, what do factory systems generally have on 1994, 1995 Pontiacs and Oldsmobiles?
Thanks.
Old 08-22-2002, 11:50 PM
There's gotta be someone that can help me out?
Old 08-23-2002, 07:14 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
From =http://www.edmunds.com/ownership/tec...1/article.html
Amplifier output is typically measured in watts per channel, with a normal stereo system having two channels, left and right. You'll frequently see "RMS" after the wattage figure — this stands for "Root Mean Square," which is a mathematical measurement of the magnitude of the AC signal. More watts means more power output to the speakers, which in turn means louder volume.
- So basiclly RMS is the average power the amp / head unit will put out.
Make sure the figures you are given are RMS not "maximum power"
Old 08-23-2002, 01:04 PM
So what do stock receivers generally put out in a Pontiac or Olds?
Old 08-23-2002, 03:48 PM
Whitey001 Whitey001 is offline
Not sure about the stock sterio but i agree and if u dont ask to see the manual some companies selling equipment to u will give u wrong info. like for example u can have 2 amps that are 1000 watts but unless u check to be positive thats the rms or root mean square basically the rms is the ammount of power it will play at continuasly. So if u get an amp that says 1000 and thats peak well yeah u might hit that a couple times but not alot of people know that thats peak or if its rms the company just says its 1000 watts. So be careful when shopping:greenchai
difference between 90 rms and 150 rms PlayStation3 Car Audio 2 10-11-2007 07:06 PM
would a 1000w rms amp blowout a 1000w rms sub??? org04stang Car Audio 7 07-07-2004 12:47 AM
Uh.. Huh huh.. If you have to ask, you'll never know.. huh huh huh... djAkira36 Stress Release 19 09-15-2003 06:18 PM
RMS Supercharger on 2002 330i Brooks 3 Series 1 05-01-2003 10:19 PM
calculate stereo rms wattage? ricodemus Car Audio 2 04-01-2002 11:00 AM
