Old 08-14-2006, 09:30 PM
CamaroRScrazy CamaroRScrazy is offline
oil pan gasket replacement
I read the instructions about the oil pan gasket replacement for a V6 Camaro. I'm really scared. They said to raise the engine a little bit and remove the engine mount.
I do not have a hoist.
Anyone did this before?
Old 08-15-2006, 05:31 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: oil pan gasket replacement
get under your car and see if you can acess the pan..if you can, no need to hoist.. if theres braces under it..you do probably have to pull the engine
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 08-15-2006, 11:08 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes. You have to lift the engine up about ~3" in order for the pan to clear the crank throws when you take it off. Make sure you have clearance all around the engine before you do this too - check for clearance at the distributor etc. It's not as bad as it sounds - take the through-bolts off each mount, lift engine (you can use a floor jack with a block of wood on the oil pan sump, you don't need a hoist). Place a 2x4 block between each car and engine mount, with the 4" side (actually 3.5") being the dimension between the two halves of the mount.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-15-2006, 02:21 PM
Thanks a lot.
You said I can use a floor jack with a block of wood on the oil pan sump. But how can I take the oil pan off, if the engine is raised via the oil pan?
Old 08-15-2006, 03:26 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Then you rmay remove the the jack.
Old 08-15-2006, 03:31 PM
Got you. Thanks.
But will the engine fall off when I remove the jack without the mount? When I raise the engine up and down like that, will it hurt the connection with the transmission?
Old 08-15-2006, 03:41 PM
wrightz28's Avatar
Oh, didn't notice that the remove the trans mount bolts was missing from his instruction. But the point here is you set the motor down with the wood block s in between the motor half the mount and the "frame"rail side of the mount and that takes the place of the jack. I prefer a 4 X 4 myself, may require some shaving.
Old 08-15-2006, 03:51 PM
Appreciate!
Below are two steps mentioned in the instructions by Autozone. I can not understand why is it necessary to do these.
  1. Remove the alternator.
  2. Remove the ignition coil.
Old 08-15-2006, 03:54 PM
wrightz28's Avatar
I think it meant disconnect the coil as a safety precation
Some models have clearence issues with the accesories. That may be where the alt. comes in to play, but I don't htink you should have any problems, I've never removed one for lifting the motor up.
Old 08-16-2006, 08:03 AM
I see.
My car's previous owner must think he was driving a Hummer. I saw a huge dent on the oil pan sump. Hope I won't crash the oil pan by supporting the engine from below.
