hey guys i have a 91 crx. its dropped and i now have really bad negative camber. i was wondering what i need to fix it. i searched for camber kits but they seem to come with different things all the time..so for the back i need adustable arms and for the front i need adjustable ball joint adustable control arms and is there anything else? theres this other thing that i see all the time but i can never find the name of it.. it always just says camber kit its for the front wheels and it comes with 4..im not sure if i need it can anyone tell me what else i need..does any one know a site where they sell a complete kit i mean with everything i need for front and rear any help is appreciated.
Re: negative camber
For the back you can use washers, the front most of the kits are offset bushings for the upper control arms. I dont think anyone makes adjustable control arms fro the fourth gens, skunk2 makes them for the 5thgens, but they wont fit.
Re: negative camber
so thats all i need? and do u know a site that ahs those items for cheap?
Re: negative camber
ebay!!!
-tony- 2000 honda s2000 |
Re: negative camber
if anyone has a camber kit on a 91 crx can u tell me what site u bought it from and the parts that were included . leschwab tires is trying to charge me $650.00
Re: negative camber
Re: negative camber
Hey guy, I'm going through the same problem, gotta 91 Civic Si. Whatever you do, don't get the camber kit for the upper control arm mounting brakets on the front. I have stock springs that are saggy just a bit, and bought those for a quick fix. However, they only push the arm too far forward, and end up bottoming out on the ridge between where the fender and inner fender well meet. My brackets are only adjusted half the way out, and don't see how they would work at all if the car was actually lowered. Adjustable ball joints seem to be the only way to go on the 4th gen. As far as the rear, (like someone mentioned earlier), washers and longer bolts will work fine. Although, if you want to just purchase a kit, Ingalls makes both kits(#35590 is the ball joint kit, #38930 is the bolt and washer kit). I've looked around an suprisingly Summit Racing is the cheapest for both kits( even cheaper than Ebay), I paid $161.23 for both shipped. Just type in the model numbers in there search bar to bring them up. (www.ingallseng.com) is the website of the company if you want to check them out.
Re: negative camber
ok as far as my 2 cents the adjsutable camber thigns for the front are worthless they raped my tires big time when i had them on. i switched back to stock thigns and my tires as so much better off.
06 cbr 600 f4i 91 civic hatchback. 96 nissan pathfinder |
Re: negative camber
Mine are adjusted all the way with almost no problem, it did bump a little bit.. so I took a grinder to it and voila!, my tires were getting eaten alive before...
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
