Old 08-14-2006, 04:54 PM
tabbie07 tabbie07 is offline
How to Replace Radiator Cooling Fan
Hi , I have a '97 Sunfire , can someone tell me how to replace the radiator cooling fan, i dont know how to get it off.
Thanks!
Tabatha
Old 08-14-2006, 05:04 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Re: How to Replace Radiator Cooling Fan
Fig. 1: Remove the retaining bolt for the fan assembly
Fig. 2: Unplug the connector for the cooling fan and ...
Fig. 3: ... remove the fan assembly out the bottom of the vehicle
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Unfasten the cooling fan mounting bolt.
  4. Detach the fan electrical connector, then remove the coolant fan assembly out through the bottom of the vehicle.
To install:
  1. Raise the fan assembly into position through the bottom of the vehicle.
  2. Attach the fan electrical connector, then install the mounting bolt. Tighten the bolt to 53 inch lbs. (6 Nm).
  3. Connect the negative battery cable.
Old 08-14-2006, 06:57 PM
THanks so much for your help. now one more thing lol. Can you tell me how to replace the heater coil. This will be the last question....hehe Thanks again~
Tabatha
Old 08-14-2006, 07:05 PM
oppps make that " heater core" haha
my99cavy's Avatar
are you talking about the heater core??
Old 08-14-2006, 07:06 PM
my99cavy's Avatar
  1. Disable the SIR system, as outlined in this section.
  2. Disconnect the negative battery cable.
  3. Properly drain the cooling system.
  4. Raise and safely support the vehicle.
  5. Detach the heater hoses from the heater core.
  6. Carefully lower the vehicle.
  7. Remove the instrument panel.
  8. Remove the DERM with the attaching bracket.
  9. Detach the heater core cover.
  10. Unfasten the heater core mounting clamps, then remove the heater core.
Fig. 1: Exploded view of the heater core and related components
Old 08-14-2006, 07:17 PM
omg where do you get all this at.
How do I make this pic bigger, when i click on it ,it sends me to " page not found"
Old 08-14-2006, 07:19 PM
my99cavy's Avatar
lol I have my spots lol but what pics do you want larger??
Old 08-14-2006, 07:24 PM
my99cavy's Avatar
Old 08-14-2006, 07:31 PM
thank you soooo much!!!!!!!!!!!!
Old 08-14-2006, 07:34 PM
my99cavy's Avatar
hey no problem!!! any other questions dont hesitate to ask.
