Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-14-2006, 04:06 PM
Cooper04 Cooper04 is offline
Send a message via Yahoo to Cooper04
Brake Light Problem
Has anyone ever replaces the top rear brake light on a 2000 Chevrolet Tahoe LT. My top LED brake light does not work and I was wondering if there is a fuse for the brake light or does the unit itself have to be replaced? Thanks a lot for your help.
Old 08-15-2006, 09:24 AM
jthomp23777 jthomp23777 is offline
Re: Brake Light Problem
I presume you are writing about the third brake light above the tail gate. I have a 2001, not sure if the same design but is LED. Remove the unit, should be a sealed one piece unit. A couple of screws and has a pig tail plug harness.If you have a voltage meter, test the dsconnected pig tail when someone stepping on the brake. If you have voltage, than you know the LED is burnt, very common, otherwise a problem somewhere else. I found mine used on Ebay for about $75.00, other wise over a $125.00 at the dealer.
Old 10-30-2010, 06:52 PM
PocoBites PocoBites is offline
How do you access the pigtail? I have the new one but cant get the old one unplugged
Old 10-30-2010, 07:55 PM
Scrapper Scrapper is offline
AF Premium User
look behind your lite after you get brake lite out where bulds and there just the plug in. when you get your brake lite loose from there thers a wire plugin like hes telling you it's really simple to unplug but he's calling it a pig tail because that's what it is called.
Old 11-01-2010, 09:34 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
The plug is recessed back inside the roof. There should be a rubber plug. Pop it out and gently pull on the wires, the plug itself should come out shortly after the rubber plug.
Old 11-02-2010, 11:26 AM
bass_caster bass_caster is offline
the plug is pushed way down in there. pull the rubber gromet out and gently pull until you get the connector out.
FYI...
for those that havent bought a replacement yet, chevck ebay and amazon. you can get new replacements for about $50.
