Old 08-14-2006, 03:29 PM
jfdsdime jfdsdime is offline
97 to 98 conversion
is it possible to put a 98 dash in a 97 model? ive read on other forums that said u could and others that said u can't so any help would be appreciated
Old 08-15-2006, 07:32 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 97 to 98 conversion
Physically it will fit...(minor tweaking of the braces has to be done) The problem is the gauge cluster. In the 98+ most of the signals for the gauge cluster run through the BCM (body control module) 95-97 don't have a BCM perse and cannon generate the proper signal to the cluster via the class to serial line. The 95-97 cluster get their signals directly from the sensors for the most part. Now if you wanted to to a custom cluster with lets say autometer gauges on a template, that would probably work out well...
