Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-14-2006, 03:14 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Weird TPS and IAC and TB problem
Hey all;
So today I ripped off the TB to try to get the TPS to read 0 at idle at 100 at WOT (no luck) and put it all back together normally. No changes made. When I started the car, the engine clunked and chugged. I remembered I sparyed quite a bit of TB cleaner into the intake so I figured it was that. I started and turned off the car multiple times to burn it off. After a couple, it was fine, but the idle sucked, the CEL was on, and the engine sounded really low. Like the sound was a lot lower than normal (actually sounded pretty good).
I took to Autozone to get the CEL tested and it was the TPS and IAC errors. Had them reset it. Drove home fine. Logger showed TPS fine readings, but the SAFC was reading 0% throttle. It started showing movement when the throtttle is almost half open. What can cause this? I reset the ECU and havent readlly driven it yet, but it was idleing better. Any ideas on what caused the CEL and the SAFC to not read the throttle until about 50% open? The SAFC starts at 0 and goes to about 45%. 0 starts at about 50% according to the logger. Any ideas? Yes, the connectors are plugged in. Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-15-2006, 12:58 AM
david-b's Avatar
Dave is THAT guy
Re: Weird TPS and IAC and TB problem
While driving to work the Throttle on the SAFC worked fine then. Must have took a long time for the reset to kick in on it. It only reads up to 80% however. Before when playing with the TPS and all, it started off at 76% and then over time went up to 90%. The car ran fine the whole night. Yeah.
75 Monte Carlo
Old 08-17-2006, 10:11 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I wouldn't suggest getting carb cleaner in those sensors... wait for that carb cleaner to dry to... I've been told it can hydrolock the engine...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 08-17-2006, 10:23 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You would need to spray an assload of carb cleaner in there to hydrolock the engine. Actually, I don't even know if you could spray enough to do it because it would evaporate over time.
95 Talon TSI AWD
97 Eclipse GST
Old 08-17-2006, 10:25 AM
Mikelb's Avatar
There's some carb cleaner that's "non-flammable"... I think that's the kind they meant when they said it, but they weren't specific
Old 08-17-2006, 07:21 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
The car will stutter a little if you spray a bunch in, but never heard of someone "hydrolocking" their car because they sprayed too much in. I fucking gunked that shit all over inside my TB, and it hesitated a little but that was it. I litterally used 1/4 of a bottle and let it sit for about 10 mins before starting it.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-17-2006, 10:51 PM
Mikelb's Avatar
ok, my mistake... they were talking a/b brake parts cleaner (it is a cleaning fluid and does really well with the gunk, but not good to get in motor, referring to the non-flammable kind)
