| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
whats a safe PSI to run?
At what PSI for turbos is it safe to run,i was talkin to a kid with a jetta and he runs 24 PSI,also how exactly does a supercharger work?..it runs off the belt right?
Holland Speedway Lake Erie Speedway Tioga Speedway (R.I.P) Wyoming County Speedway Lancaster Speedway Motordrome Speedway Mountain Speedway Eriez Speedway Stateline Speedway Many more to come.... |
Re: whats a safe PSI to run?
That depends on the turbo, the engine, the fuel system, and quite a few other factors. If you want to know how a super-charger works look at the sticky at the top.
like polygon said, it depends on a lot of factors. But in general, small displacement engines can run more psi than larger displacement engines due to the simple fact that smaller engines draw less cfm than bigger engines. It requires more psi to push the same amount of cfm as a larger displacement engine. FWIW, more boost is not always better. There is a limit to every turbo to where it can keep making more boost, but the amount of heat generated actually decreases hp. Believe it or not, I actually know some subura wrx guys that are boosting their turbos beyond its efficiency.
Also, factors such as compression, what size turbo, whether the system is intercooled, altitude, weather conditions, what octane gas, and how well the car has been tuned all play a major role in boost.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
thanks taht all helps..what is cfm?..cubic fuel per minute?idk anyway by the way that contour looks pretty crazy.
Even at 15psi (pressure ratio = 2) the efficiency is on the way out. I've heard of clowns trying to run these at 20psi. Some turbos can efficiently boost to well over 30psi, but they aren't very common in passenger cars.
A properly sized turbo will not be any different on a 1.0L engine, or a 12.0L engine. They both will boost efficiently (reasonable charge temp vs psi). Turbo efficiency doesn't go down just because you are flowing more air...well, I should say, its not that simple anyway. Anyone that runs 24psi on stock internals without some very carefully thought out engine management system designing and fuel type considerations, is sitting on a very short lived time bomb. But then, you didn't discribe the details of the motor and system. If you spend enough money on a motor, you can make it live through some pretty amazing things. But I assume you're not looking to spend that kind of money
life begins at 10psi of boost Three turbo'd motorcycles and counting.
All the info i have on the car is its a 4 door jetta,he mentioned something about a computer chip where he can control the boost,im guessing a boost controller,and other than that I dont think he has any internals done or fuel but I will ask him.
Another major factor is the compression of the engine. If you have a high compression engine, forcing extra air can be dangerous. Take for instance my Maxima engine. I've read that unless I want to do some major engine work I shouldn't push any more then 6 PSI. Which may not seam like a lot, but in my engine it is. Anything over 6 I chance some major damage to the engine.
I hear about a lot of honda moders that blow their engins very quickly for this very reason.
WHAT KEEP IT STOCK! Well that takes the fun out of it. [center]
Ill find this out from him as soon as i can,also compression ratio I know is measured in the cylinders?..could someone explain this CR to me in details please?
The compression ratio is between the volume of a combustion chamber and cylinder, when the piston is at the bottom of its stroke and the volume when the piston is at the top of its stroke. The higher the compression ratio, the more mechanical energy an engine can squeeze from its air-fuel mixture. Higher compression ratios, however, also make detination more likely.
You make horsepower by how much air you move through the motor. A high compression 10:1 engine is more efficient than a 7:1 engine, so the 10:1 engine gives you more bang for the buck because the lower compression is not as efficient, it has the ability move more air through it. So, with boost, the 7:1 engine could get a higher compression ratio, which will not cause detonation, and be moving extra air, making more horsepower than the 10:1 engine. The 10:1 engine could be in self-destruct mode and have detonation if you push the same amout of boost through it as you do the 7:1. It's a touchy process. You have to know what you are doing to make sure you dont blow the engine. Often times mods are required to help handle the higher compression ratio from a turbo or super charger.
Ok,I understand that but I hear detonation alot,is that when the internals go and the motor blows up?
detonation is also refered to as pinging, knocking, pre-ignition. Its when something causes the air/fuel mixture in the combustion chamber to ignite before the ignition spark.
What causes it is heat, fuel vapor will ignite at a certain temp, if there is too much heat (a hot spot or what have you) in the chamber, then it will light it off too early. When you increase boost and/or compression ratio, both of those things will add heat. When you ignite it too early, the piston is still traveling upward, and the flame front collides with the piston. This creates extremely high cylinder pressures and things can break....in quite a spectacular fashion. Detonation is very bad in a boosted engine, because there is so much more force behind the explosion, it can severely damage the motor very quickly. Unlike most naturally asperated engines, which can suffer some occasional detonation with no noticable side effects. It can break con rods, melt pistons and shatter ring lands. Its the #1 enemy to building a turbo'd engine, and its the limiting factor to what boost you can run.
Well this guy who lives near me always claims that his lifters are "knocking"..is this a different "knocking" from what you just explained?
