Old 08-14-2006, 12:13 PM
Dizmatic Dizmatic is offline
98 GL 3.8 - Brake light on dash appears for a few seconds then disappears
I notice recently that the brake light on the dash would appear after I would come to a complete stop and start driving again. Then it will go off. It does this a few times and then it doesn't. Can someone who may have had a similar issue assist me in pinpointing the problem?
Old 08-14-2006, 03:56 PM
usarmydog usarmydog is offline
Re: 98 GL 3.8 - Brake light on dash appears for a few seconds then disappears
I had the same problem on my 99 windstar, ironically the light went away after I topped the brake fluid off, haven't seen it since.
Old 08-14-2006, 05:02 PM
Death to Ford Death to Ford is offline
usarmydog is right, you have low brake fluid
Old 08-15-2006, 08:48 AM
What brand of brake fluid would you recommend for my vehicle. Thanks for the replies guys.
Old 08-15-2006, 11:23 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
DOT 3 brake fluid. Available at all parts stores.
Old 08-15-2006, 11:48 AM
DRW1000 DRW1000 is offline
Johnny Mullet is right in that you need DOT3 - which of course is not a brand but a specification. Any quality brand should be fine.
There is a brand at my local parts store that lists a DOT3 that is specific for Fords. It has a dry boiling point of 550 degrees which exceeds the DOT3 requirements. the reason that it cannot be rated DOT 4 (higher boiling point) is becasue its wet boling point only meets DOT3. Any DOT 3 is fine.
Old 08-16-2006, 07:27 AM
Thanks guy. That did the trick.
