How to find out what sbc you have..
I know i have a small block 350, i m just not sure if its 2 or 4 bolt and what verson it is, i hear they made 4 different models or something like that generation 2, 3, etc .. How do i find out all the info about my engine? It was built by the previous owner and had about 750 miles put on it and i want to start doing some more work to it i just want to know everything about it first.. i have some pics of the bay but nothing to close up yet if somebody wants to have an idea
Re: How to find out what sbc you have..
Have the engine id # checked. It's on the front of the motor just below the cylinder head, right side I believe.
is there a site i can enter it in at like the online vin check things?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
go to google and type in gm engine codes and look at a few of them. they usually have a list and you just scroll down till you find yours, the numbers is also on the back right of the motor near the drivers side cylinder head, its on the bell housing part so its facing the sky, grab a light and look at it.
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
I use this site but its not the most current so I am sure google like recommended will have nice results http://www.thedirtforum.com/castings.htm
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
I Have A Book to check block numbers and head numbers so if you get me the numbers of the back of the block i can tell you what you have
awsome rebel, ill get you the numbers i find once i get out there
No Prob
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
^thats what i use
The HappyHydrocarbonBoy is right. Mortec can sometimes be a little slower in getting updates posted, but their data seems to be the most accurate.
There are so many variations built within the same casting number that you never know what you've got. You'll often find you may have to look at the additional casting number in the timing chain area or near the rear cam plug to determine it you have a high nickel/tin block or not, even though the casting numbers might be the same. Frankly, you're actually probably better off starting with a two-bolt block, then machining for four bolt splayed main caps. They're quite a bit stronger than the factory 4-bolt arrangement. You can usually find the casting numbers you'll need in either place: ![]() ![]() If you look behind the timing cover, you might see either the numbers "010" or 020" which denote whether the block was cast with iron alloyed with either 1% or 2% extra nickel, respectively:
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
the book i use for checking engines was published by chevy
