Old 08-14-2006, 11:06 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
Compression
What is the stock compression on an 89 Civic Hatch 1.5 D15b2?
I need to find out whats wrong with my motor!!!
Old 08-14-2006, 04:31 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: Compression
idk the stock compression, but have you done a compression test?
-tony-
2000 honda s2000
Old 08-14-2006, 05:38 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: Compression
you talkin compression ratio or like psi per cylinder. because for a d series its about 9.2 to 1 as far as ratio and i woud lsay between 155 and 170 or somethign as far as psi. i msure im alittle off. but tis my best estimate for u.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 08-14-2006, 08:12 PM
Re: Compression
my b16 runs 180 psi in each cylinder
-tony-
2000 honda s2000
Old 08-14-2006, 09:47 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Compression
Yea, they got it close. I don't know what the exact psi is, but 155 should be a minimum, its a sign its starting to need a rebuild but still running alright. If you end up with something around 100 or lower, you have bigger issues and at the point of needing a rebuild badly. If its like 25 or less, better check your valves because either 1> one is sticking on you, 2> one is bent, or what i ended up getting 3> broken valve which is usually a result in 0 compression.
Tony
91 Civic Sedan DX - Stock 287k Miles
