Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-14-2006, 09:30 AM
kgaul kgaul is offline
Question 91 4 runner/ power windows not working
this weekend all 4 power windows stopped working. Rear window and moon roof are working. Checked continuity in circut breaker/ fuse and is good. I am baffeled any help would be greatly appreciated since it's going to rain tommorow and my windows are half way down. PLEASE HELP ME!
Old 08-14-2006, 07:19 PM
KimMG KimMG is offline
AF - Advisor
Re: 91 4 runner/ power windows not working
Did you check the lock switch on the driver's door?
Old 08-15-2006, 08:33 AM
Question Re: 91 4 runner/ power windows not working
Yes, First thing thanks for the reply, I checked that first. However the problem is solved. Last night took the door panel off. Remember when taking that off to slide door handle in and foward to release from inside mount. FYI anyone who reads this. Wire harness on inside door was attached and caused the connection to pull apart when i opened the door. My guess at how the two pulled apart. It was nice to find this out instead of some massive electrical problem.
My digital clock and radio display were not working either. Says to use a 15 amp fuse; mine did not work with the replaced 15 amp fuse; so i used a 20 amp fuse.
ARE THERE ANY PROBLEMS THAT MAY ARISE BECAUSE I SWITCHED FUSES??
THANKS
