Old 08-14-2006, 07:02 AM
TMC2k1's Avatar
TMC2k1 TMC2k1 is offline
oxidized drl's
Id love to get the DRL's to shine like the fog's. How would i go about doing this? When i do this i plan to change to a white bulb as well
2001 Pontiac Firebird 3.8L A4
Current Mods
SLP CAI & Whisper Lid with K&N Air Filter
Future Performance Mods
Magnaflow Catback Exhaust
Pacesetter Headers
Old 08-14-2006, 09:54 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: oxidized drl's
I use polishing compound, followed by wax on faded plastic lenses.
Works pretty good unless the fading is extreme. I have to shine up my crown vics headlights about every 6 months or I cant see well in the dark.
Oreallys sells these little "scotch brite" looking sanding pads, for finishing up primer coats before you shoot your car with actual paint. Get the finest one you can they sell them in several different varieties. If you get one of those and remove the crud off those lenses, you can spray them with high gloss polyurethene enamel, and have them looking like new.
Old 08-14-2006, 09:57 AM
TMC2k1's Avatar
Re: oxidized drl's
I do have polishing compound. Would liquid wax work?
Current Mods
Pacesetter Headers
Old 08-14-2006, 10:00 AM
Re: oxidized drl's
yeah works good. be sure to hit them with the polishing compound a few times first tho or the wax will dry into the oxy and turn them white. You will see the difference pretty quick. If you use a clean white rag you will see the crud coming off the lenses is tainted yellow. If you can hit us with some before and after pics. I bet you will be pleased.
Old 08-14-2006, 10:17 AM
TMC2k1's Avatar
Re: oxidized drl's
thanks. Im gonna do this tomorrow because im gonna pick up some clear bulbs for the drl's as i hate those orange ones. How exactly do i go about removing the DRL's
Current Mods
Pacesetter Headers
Old 08-14-2006, 10:31 AM
Re: oxidized drl's
Im not sure really looks like you have to lay under the bumper, and you might have to remove a piece of the black plastic air dam to expose it. A friend of mine has a car that looks almost exactly like yours, but hes removed the lights in the front bumper to run brake cooler tubes. I bet if you get together a quarter inch ratchet and grab up a 8mm and a 10mm socket, it will probably be one of those. some of the other guys on the forum who actually have one could tell you EXACTLY how to do it, but i bet if you got into position, its pretty much self explanitory.
