Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-13-2006, 11:11 PM
baker1234 baker1234 is offline
turbo integra!
so im new to the honda/acura world im confused on a few things....i know about turbos and all that i own a 97 gst but want to purchase a LS integra or GSR and turbo it..what made me want to do this is, my buddy ronnie has a LS with a 57 trim turbo running 4 lbs front mount dsm inj blah blah his car pulls so hard and now i want to build one,, the question i have is if i get the turbonetics kit with the front mount and everything what injectors should i run and should i run a walbro 255 fuel pump and im really confused on ur ecu's, ive been reading up alot about hondata and all that but if i was to get an ls what fuel set up and tunning and ecu should i get and if i got a gsr what setup i should get thanks guys!!!and i dont want to run internals so im guessing id bosst 4-7 lbs?
1997 gst (5speed)
Apexi 3" turboback
k&n intake w/hardpipe
greddy type s bov w/ piping
Apexi SAFC2
new revised 3g lifters
magnacore 10.3mm wires w/ new plugs
Old 08-14-2006, 04:44 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: turbo integra!
Originally Posted by baker1234
...the question i have is if i get the turbonetics kit with the front mount and everything what injectors should i run and should i run a walbro 255 fuel pump and im really confused on ur ecu's, ive been reading up alot about hondata and all that but if i was to get an ls what fuel set up and tunning and ecu should i get and if i got a gsr what setup i should get thanks guys!!!and i dont want to run internals so im guessing id bosst 4-7 lbs?
we'll if you know about turbos, then why are you asking fuel questions? shouldn't u know already?injectors I would run would be 440cc, yes, upgrade the fuel pump,probably the fuel rail too,you'll be fine running 5 psi with the stock ecu. if you know how to tune than get the hondata s200 or s300.
-tony-
2000 honda s2000
Old 08-15-2006, 03:18 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: turbo integra!
4-7psi...dont waste your time
You DSM guys have to learn a little more about reliability...i'm not exactly pushing my setup hard at all and the numbers are in the signiture. Personally if you're going to turbo a Honda, you need to read up on it A LOT and piece a kit together on your own because kits from Turbonetics and Drag are a total waste of time. I paid a lot less for my setup and i have a lot more quality parts than a Drag kit or Turbonetics kit is going to provide.
www.honda-tech.com
www.homemadeturbo.com
www.turbod16.com
those are all good places to start...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
