Old 08-13-2006, 09:31 PM
mdtie mdtie is offline
Question 97 Cavalier Cooling Fan
my cavalier was overheating, changed thermostat and bled system ... now have to turn on AC to make radiator fan work ... is there a sensor that should tell the fan to come on w/o the AC on ? ...
Old 08-13-2006, 10:08 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: 97 Cavalier Cooling Fan
was or is??
the fan kicks on when your temp guage gets to about 3/4 (usually only does it when your sitting still for quite a few minutes)
if it doesnt come on, then it could be either your "coolant temperature sensor" or your "cooling fan relay"
if your temp guage (in your dash cluster) is working fine, then your coolant temperature sensor probably isnt the problem
if you wanna know how to test the relay, let me know, ill type it all out
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-15-2006, 06:10 AM
YES Please tell me how to test the "cooling fan relay" !
Old 08-15-2006, 08:14 AM
Old 09-03-2006, 11:59 AM
dnorman_Sv dnorman_Sv is offline
I'm having the same problem. I've tested the relay and it seems OK. Did you get yours fixed? If so, what was the problem?
Old 09-03-2006, 10:44 PM
how about the fuse? did you check the fuse?
