Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-13-2006, 07:11 PM
machete619 machete619 is offline
Send a message via AIM to machete619 Send a message via Yahoo to machete619
removing hand brake
i need help removing e-brake cover so i can put this one i bought
Old 08-17-2006, 03:56 PM
Bear Bear is offline
Re: removing hand brake
First let me tell you what I tell anyone who wnats to work on their own car, buy a service manual, and the haynes will work for most repairs and it is inexpensive.
OK you first need to remove center console (two screws in bottom of cup holders and four screws in bottom of console and also take the gearshift knob off).
Next: lower parking brake handle (be careful working on the calbles as there is a clock spring pre-loaded to 20 lbs ft of torque, you need to start by pulling the parking brake cables to the rear until you can insert a 3/16 drill bit or small screwdriver all the way through the parking brake lever mechanism) release both parking brake cables from the equalizer, unplug electrical connector ground from brake warning light switch, remove nuit/s attaching parking brake lever assembly from center console.
If you had a Haynes, all of this and the pictures as well would be right in front of you.
Old 08-17-2006, 05:12 PM
