Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 08-13-2006, 05:51 PM
nikita7's Avatar
nikita7 nikita7 is offline
will 14inch rims from 1992 miata fit on 1993 323
Title says it. Any of you guys know will they fit ?
1990 TSI AWD.
JDM redtop 4G63T
4 bolt rear end
91 transmission
CF hood
No-name intake
Reverse glow gauges!
Old 08-15-2006, 08:17 PM
stamar stamar is offline
Re: will 14inch rims from 1992 miata fit on 1993 323
ok what you need is 4 x 100
this is the size most common to mazdas, and also to honda civics.... toyota tercels....
and you need like um 5-7 inch wide.
No idea if that is your miata. in general there are many proteges using miata wheels. but there are some miata wheels that wouldnt work as well.
If you want to keep the same tires you need the same rim size.
I dont recomend getting bigger than 14 inch. The reason is that stronger struts are not easily available on the market for our cars. Ok and you removing rubber from the wheel puts more stress on the shicks in your car, and unfortunately the stock struts are better than any for sale in the us so when you kill those you need to put kybs on, and they are worse.
hopefully that helped any other questions post away. Im looking into the same sort of thing for my 95 protege.
97 sentra gxe auto 174k miles
89 nissan d21 truck z24i 213k miles ( with a cabover camper)
Old 08-16-2006, 07:44 PM
nikita7's Avatar
Yes they would fit. But it seems that only tires availible for miata rims are just 1CM wider than 13 inch tires I already have. I am thinking of buying 15-16inch tires so car would at least have some grip in turns.
But most likely I will let wheels/tires stay stock for a little while. Tires are brand new, so it would be a waste. After the car is repainted and I will be 100% positive about the engine swap possibility I will buy a set of 16s for it and start scaring V8s 8).
P.S. The owner of custom speed shop around here suggested that it IS possible to stick LS1 into 323. I know it would be time consuming and plain insane but....
...Pulling up to the light in 2200lb car with a 5.7liter V8. Oh man, priceless.
1990 TSI AWD.
JDM redtop 4G63T
4 bolt rear end
91 transmission
CF hood
No-name intake
