Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-13-2006, 04:44 PM
ksmom ksmom is offline
Tail light trouble 97 Crown Vic
Ok, the tail light needs to be changed. I understand this isn't difficult so I want to do it myself. I got my manual out and read and read, and looked in the index and read again, and there is Nothing on changing a tail light. I got online and looked and can find nothing anywhere on how to do this. Now maybe it is so simple that no one else thinks it needs directions but I am lost. Can anyone help?
Old 08-13-2006, 06:38 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Tail light trouble 97 Crown Vic
Open the trunk, if it has a trunk liner, there are small plastic pieces that hold the liner in. Remove the liner holder. Pull the liner back and there are some plastic nuts on studs. I think there are 3. Remove the plastic nuts and pull the tail light assembly out of car. Twist the light sockets to remove from the housing. Pull bulb out and replace bulb. Install all parts and you are done. It is a good idea to check to see if the lights work properly BEFORE you install the light housing.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-21-2006, 05:34 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Thats exactly it. Also when you put the lights back on the car before you crank the plastic wingnuts back down, take notice of the little plastic pin on the back side of the light opposite to the tag. If you dont line it up perfect with the hole its intended to find you will end up with a tailight that sticks out a little on the outside edge and it will be noticable from a side view.
Old 08-23-2006, 08:18 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Hello
Make sure you check all your bulbs before you button everything back up.
Mike
