Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-13-2006, 04:04 PM
DPierce86 DPierce86 is offline
1989 crown victoria car chime
The car chime won't shut off when car is running. If key removed it will shut off.
I need help asap drives my nuts to drive with the noise
Thanks for any insight
Old 08-13-2006, 05:14 PM
KimMG KimMG is offline
AF - Advisor
Re: 1989 crown victoria car chime
Are you wearing your seatbelt? Need to check the seatbelt switches to make sure they are working correctly. Check the door switches.
Old 08-13-2006, 06:41 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Remove the lock cylinder and there is a small ground tab on the side of the cylinder. Make sure it is making good contact when installed. You can bend it a little if needed. The grounding tab can also be totally removed without any adverse effects.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
