Old 08-13-2006, 03:28 PM
chopstick1981 chopstick1981 is offline
How do i remove glass from hatch
I need to removethe glass from the rear hatch on my 91 civic Is there an easy way to get this done? Is it just glued in there?
Old 08-13-2006, 07:30 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: How do i remove glass from hatch
put a w7 in the back and turn it up. or use a spark plug, well anything ceranic, baseball bat, you know, go get a prfessional that installs glass!
-tony-
2000 honda s2000
Old 08-13-2006, 07:42 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
yeah its glued but its pretty thick on there. you have to remove the weather stripping then get a glass removal tool that cuts the glue.at least thats how most windows work, not sure on hatches tho
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-13-2006, 08:49 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
You can go get a removal tool(cold knife, i believe is the name of it), which if your not careful, you might as well just take a baseball bat to it because it can break it. Or take the weather stripping out and get some piano wire, run it through the glue, wrap each end around a screwdriver and start sawing, works pretty good in the hot weather, thats how we remove them at the salvage yard.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-13-2006, 09:13 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
I was at a lack of wire one day..took me for frikkin ever to get the lower glass out of a hatch, and I was using everything I had...those little windows are pretty damn strong, and flex alot! makes me wonder why mine shattered so damn easy..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-01-2006, 09:09 PM
Mark_Z28 Mark_Z28 is offline
When I removed the glass from my 88 wagovan I used a razor blade cutter tool and a steak knife, lol. Took a while but it came out unscathed and in one piece.
Old 09-02-2006, 01:44 AM
FrodoGT's Avatar
Same, I used a razor knife, regular knife, part of a hacksaw, several screwdrivers and a piece of metal I found in the junkyard, needles to say, the rubber was shot.
Current project:
Rio Red 91 hatch.
Old 09-03-2006, 07:44 PM
I will have a pro come and remove the scratched rear window of my other 88 wagon and I can install the window myself. I didnt care about the parts car window frame so the scratches and crap dont bother me. Dont want to scratch the good one up though.
