Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-13-2006, 01:56 PM
DANZIGS DANZIGS is offline
1/4 Mile Time?
I have an 89 Caprice with a 305 tbi th200 4r and 2.73 rear gears. The tranny has a B&M shift kit, and the motor has a 1" throttle body spacer, open air element, timing slightly advanced, and electric fans. The catalatic converter has been drilled out and a 2 chamber flowmaster installed. I have never runned the car at the local strip and I'm just curious what kind of 1/4 mile times should be expected. Is high 15's out of range?
Old 08-13-2006, 05:11 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1/4 Mile Time?
You'd be lucky if you're in the 17-18 second range. 15s are totally out. My '88 has a 350 lb/ft tq 350, 4L60 (TH700R4, much lower 1st gear than your TH2004R), 3.08 gears and 225/70R15 tires and it's a 16-17 second car. There's just too much weight, not enough torque, and not enough gears to get it to 15 in your case.
Of course, the torque rating of my engine is estimated - it's not dyno'ed, and the engine does have over 1/4 million miles on it since its rebuild in 1993 - it may not be producing quite that much anymore.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-13-2006, 05:55 PM
HLandin's Avatar
HLandin HLandin is offline
Re: 1/4 Mile Time?
I would agree with silicon212. Stock, the Caprice never ran faster than the low 16's at the Michigan State Police trials, and that was with the 350-cid with 3.42 or 3.08 rear end ratio (depending on year), and the 700R4/4L60 or 4L60E. Even with modifications, you still using a 305-cid and 2.73 ratio rear end. You could get better times, but only with some serious modification to your engine and drivetrain.
Old 08-19-2006, 12:55 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: 1/4 Mile Time?
My '84 Caprice w/ a 4bbl carb, and 700 R4 Tranny WAY back when It was stock ran an average of an embarrasing 18.7 seconds on the 1/4 mile (average calculated with 3 runs). Now since eliminating ALL emissions & ALL computer contolled components, running high octane through a performer Edelbrock carburetor with the vacuum advanced HEI distributor set so advanced that its JUST on the verge of pinging (don't worry I make sure there is NO ping) I was able to get a new average of 16.9 seconds. Its still nothing spectacular, but its a huge jump from where it used to be.
I wanna see what headers, dual exhaust, and a new rear end will do for it, but I can't afford all that right now. The rear end is currently my main focus, for traction and accelleration reasons. My dream car would be for it to look COMPLETELY stock from the outside, but to be faster than a bat out of hell.... all while still keeping the gentle, smooth ride of a Caprice. Just wishful thinking though.
