Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-13-2006, 01:45 PM
97Bird's Avatar
97Bird 97Bird is offline
97 Steering column lock
I've never run into this problem before so before I take the covers off of the column I figured I'd ask if anyone else had had this problem and how did they fix it. The key went in fine and I started the car with no problem but when I shut it off I couldn't get it to go to the Lock position to remove the key. I should add that it isn't due to wear since the car has less then 8,000 miles on it!
The Original 97Bird
Old 08-13-2006, 05:05 PM
KimMG KimMG is offline
AF - Advisor
Re: 97 Steering column lock
Did you put the car in park?
Old 08-13-2006, 07:32 PM
97Bird's Avatar
Of course.
The Original 97Bird
Old 08-13-2006, 08:34 PM
my97tbird my97tbird is offline
where your wheels turned far enough to engage the lock? I've turned the car off with the wheels turned and had it lock the key before. If that's the problem all you have to do is turn your steering wheel enough to release the key.
Old 08-14-2006, 07:45 PM
AF - Advisor
You need to check the shift lock actuator.
