Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 08-13-2006, 12:55 PM
john43 john43 is offline
service engine light - fault code P0301
I have a 2000 Tacoma 4 clynder truck, service engine light is on with fault code P0301 on the diagnostic which indicates ignition problem in cylinder 1. I have replaced spark plugs and the combination coil/injector unit for that cylinder. I cleared the fault code and it returned. Truck runs slightly rough on idle. Fuel filter was also replaced. I also used injector cleaner addative to the gasoline. The wiring looks very complex to replace.
Anyone have any other suggestions before I spend alot dough at the dealer???
Old 08-15-2006, 01:14 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: service engine light - fault code P0301
Welcome to the AF!
Here's a troubleshooting chart for a 2RZ-FE/3RZ-FE. Hope this helps (Links go to http://www.deserted1.com/FSM/
Repair Manual 1, Diagnostics):
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Old 08-15-2006, 01:15 AM
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
