transmission 92 crown victoria lx
my 92 crown victoria lx i think is having tansmission problems it will run but it wont go into 3rd gear and it has a winning sound if you go over 40 mph.
thought it may be a gear box that controls the transmission not sure can anyone help me out a bit maybe it has happend to you.
Re: transmission 92 crown victoria lx
First check all the linkage to be sure it is going into the proper gear. Sounds like the transmission is hung in 2nd gear and that is causing the whine. If all the linkage is correct, it may be time for a rebuild.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
if it has the aod trans check the plastic bushing at the throttle body where the tv cable connects to. even if it looks fine replace it. they are like 2$ at any ford dealer and worth the insurence.
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs ![]() also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon |
What may be wrong, and both previous suggestions were good ones, has a LOT to do with which transmission you have in your '92.
Early '92s had the AOD, and those built after mid May of 1992 had the AODE. They are more different than similar. |
