Old 08-13-2006, 10:21 AM
KTem's Avatar
KTem KTem is offline
Stripping alcohol
Hey,
I'm doing a Koenig 600SL right now, but I messed the body paint up so I wanted to strip it. I got myself some 98% alcohol, which comes in quite small bottles, which are expensive as hell. The amount of alcohol wasn't enough to submerge the body in, so I figured I could mix it with Spiritus (75% alcohol) to make the amount of alcohol big enough to cover the entire bodywork. So I did just that, poured the alcohol in a plastic container and put the body in.
Aproximately three decades... cough, three weeks later, the only result is that I can scratch the paintwork off with my fingernail. The paint has become rougher and more translucent, but it can't be smeared off. Sooo, my question is, am I being impatient or is this not going to work anyway?
Thanks in advance.
Old 08-13-2006, 10:46 AM
freakray freakray is offline
AF Modelrater
Re: Stripping alcohol
You need 91% Isopropyl Alcohol.
AF User Guidelines
Old 08-13-2006, 10:49 AM
KTem's Avatar
Yeah, that's what I bought, but it's quite expensive and it wasn't enough to cover the entire bodyshell. Do you think 75% can do the job as well?
Old 08-13-2006, 10:54 AM
AMV's Avatar
AMV AMV is offline
Send a message via MSN to AMV
Just use Dot 3 brake fluid its cheap and enough to cover the body. Takes paint right off in seconds used it when i screwed my paint job on the doors of the Enzo. It wont harm the plastic, but i wouldn't recomend leaving it over night. Hope this helps.
Old 08-13-2006, 11:08 AM
AF Modelrater
75% isn't sufficiently strong to remove the paint well.
If the paint is lacquer, you may need to leave the part a few days to allow the alcohol to work. Also try using an old toothbrush to give a little mechanical assistance.
As for brake fluid, it works well except it will effect the plastic in the sense that it weakens it.
AF User Guidelines
Old 08-13-2006, 11:13 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Like Freakray sed, give it a good scrubbing with a toothbrush and some dishsoap. If it doesn't come clean, soak it some more. It sounds like your alcohol percentage is too low to get an optimal effect, but it doesn't mean that the paint won't come clean with some scrubbing.
PHOTOBUCKET SUCKS
Old 08-13-2006, 12:16 PM
klutz_100's Avatar
What kind of paint are you trying to strip? I don't think you actually saud in your post.
Try electronic stores for your alcohol - I bought 1litre for the equivalent of approx. 5USD here in Poland from an on-line store and the alcohol was packaged in German so it was probably imported!!
The alcohol stripped some TS (fresh) in less time that it took me to say "supercalifragilisticexpialidocious"
HTH
Old 08-15-2006, 03:37 PM
urjustamemory urjustamemory is offline
I had a model in a brake fluid bath for 2 weeks, and the paint is still on it. Wouldn't even scrub off with a brush. 2 weeks didn't even harm the plastic in anyway.
Old 08-15-2006, 08:09 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
How much does it cost there in the Nether Regions? It's about a dollar for a pint or so here.
Old 08-16-2006, 03:26 PM
KTem's Avatar
I don't exactly remember, I think 0.5 liter is about 8 euros, thanks to the taxes that are put on it. Same goes for Tamiya paint, by the way.
Klutz: good idea, since this Spiritus isn't going to work. The paint is too hard to scrub it off with a toothbrush.
I went to search an online store, but Dutch online stores seem to ask the same bloody amount of money for a bit of alcohol as regular stores do . Sooo, I tried an US-based store, but the ones I found don't ship outside the USA! Any ideas?
Old 08-16-2006, 03:52 PM
ZoomZoomMX-5's Avatar
That's some expensive alcohol; at Wal Mart here you can get a pint of 91%for about 80 cents. A friend ordered several gallons of 99% isopropyl from the pharmacy at a Publix grocery store, it was about $10-$12 per gallon. 8 euros for a pint is rather taxing
My Fotki Album
Old 08-16-2006, 04:38 PM
aton304's Avatar
aton304 aton304 is offline
find something called chameleon. it is a paint stripper that i found at the hobby store. it will eat the paint in about 10 min and won't hurt the model at all. i just stripped a civic that i painted about 2 years ago. put it in the solution, and took a toothbrush to it and in about an hour -- no more paint. then you strain the stuff in some cheese cloth and put it back in the bottle for the next time. the stuff works great. it costs about 20 bucks for 16 oz.
Old 08-16-2006, 06:10 PM
Wow, that is expensive. You were looking in drug/grocery stores?
Old 08-16-2006, 07:40 PM
Svendsen Svendsen is offline
I had to do the same now, but i used Break Fuide, DOT4. The paint has been on for a while and it have been painted twice so it was a thick layer. I also added some thinner, just to try it out.
I looks like it took it, gone check it closer tomorrow.
Norwegian modeller
Completed:
Not as many as undone
Old 08-17-2006, 08:56 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Hrm... thinner and brake fluid at the same time?
You should be careful when doing combo's like this.
Not sure if the two will mix tho.
Give some results 'cause I'm curious about your mix
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
